Corsair Obsidian 700 Full Tower ATX
Quicklinx: 72C7WS00 Mfr#: CC700D
Designed for Years of Performance
The Obsidian Series™ 700D is built to last through years of motherboard, power, memory, cooling, and component upgrades.
The steel structure has a matte black coating both inside out and is finished with a brushed aluminum faceplate for a professional look that's both serious and awe-inspiring.
Three Isolated Cooling Zones
The power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat buildup.
A dust-filtered 140mm fan draws in cold air at the bottom of the case and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The hard drive / SSD bays are cooled by a separate 140mm fan which vents from the case via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment.
Need even more cooling performance? The Obsidian Series 700D has pre-drilled support for top-mounted single, dual, and triple radiators, or up to three additional 120mm fans.
Advanced Features for Extreme Flexibility
Six drive bays with clever snap-in trays accommodate both 3.5" and 2.5" drives with no adapter necessary. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25" drives.
  • Six HDD / SSD drive bays compatible with both 3.5" and 2.5" drives
  • Removable CPU backplate panel for easy heatsink installation
  • Isolated cooling zones prevent heat buildup
  • Unique cable routing holes guarantee a clean and clutter-free installation
  • Three 140mm fans included, with the ability to add four more 120mm fans
  • Tool-free optical drive installation makes building a system faster than ever
  • Two year warranty with Corsair's world-class customer service and technical support
  • Dimension 24" (H) x 24" (L) x 9" (W) - (609mm X 609mm X 229 mm)
  • Material Aluminum Faceplate, Steel Structure
  • Color Black
  • Drive Bays (x5) 5.25" / (x6) 3.5" or 2.5" Internal
  • Cooling (x3) 140mm Fans / Up to 4x 120mm Fans (not included)
  • Expansion Slots 7 (+1 vent)
  • Motherboard ATX, mATX, EATX
  • Front I/O (x4) USB 2.0 / (x1) IEEE1394 / (x1) Headphone, (x1) MIC
  • Power Supply ATX (not included)
Case Form Factor
Full tower
Motherboard Form Factor
ATX
Power Supply
None
