If you want to build a Mini ITX system without compromising expansion, flexibility, or performance, the Obsidian Series 250D is your answer. Though it's small on the outside, the 250D has room for standard components like a full-size 5.25" optical drive, a full-length GPU, a 240mm radiator, and even a full-size ATX power supply. The sleek, aluminum front fascia provides the striking yet subtle design that Obsidian Series cases are known for, and a top window gives you a close-up view of your high-performance components. The 250D is a great choice if you want full size performance in a small space.
Mini ITX Without Compromise - finally a Mini ITX case that can fit most of what you'd be installing into your standard Mid Tower case in a fraction of the volume! If you ever wanted Obsidian-level flexibility in a smaller form factor, the 250D is the case for you. It comes with excellent cooling out of the box - a front AF140L fan and rear exhaust AF120L, and can simultaneously fit a full sized modular PSU, 240mm radiator, optical drive, full length GPU, and up to four drives. Now going small in size doesn't mean you have to accept less performance.
Design
- Aluminum front fascia and thick steel construction.
- Overall dimensions 290mm (H) x 277mm (W) x 351mm (D)
- Top window for component visibility.
- Thumbscrew backplate removal for PSU and hard drive access.
- Easily removed dust filters on all intakes.
- Simultaneously fit two 3.5"/2.5" drives, two 2.5" drives, one 5.25" drive, a full sized PSU, a 290mm long GPU, and a 240mm radiator.
- Front panel USB 3.0, headphone and mic ports, and power and reset buttons.
- Innovative three panel removal for sides and top panel, with thumbscrews.
- Front fan 200mm, 140mm, or 120mm compatible (AF140L 140mm included)
- Side fans dual 120mm compatible (AF120L 120mm included)
- Rear fans dual 80mm compatible
- Tons of cable routing tie downs for easy cable maintenance.
- Tool free installation of all drives.
Box Contents
- Obsidian 250D Mini ITX case
- Accessory box
- Quick Start Guide
For compact performance in a small size
The small size of the 250D makes it great for dorm rooms, desktops, bookcases, or anywhere else space is an issue. -
Black anodized brushed aluminum fascia
The front panel has an elegant look that befits the high-performance system you want to build. It's durable and resistant to scratches and fingerprints. -
Fits full-size components
Many mini ITX PC cases impose strict limitations that can make it difficult to build a well-cooled, high performance PC. The 250D has a highly efficient interior design that allows for a 5.25" optical drive, a full-length graphics card, and a full-size ATX power supply. There's even mounting points for a 240 mm radiator for advanced CPU cooling. -
Keeps your GPU cool
The interior is arranged so that the included 140 mm front intake fan draws cool air directly over your GPU. This can help with reliability and give you extra GPU overclocking headroom. -
Front panel USB 3.0 and audio I/O
You want to build a system that's not only fast, but easy to work with. Up-front USB 3.0 and audio connectors let you quickly attach high-speed storage devices and headsets. -
Windowed top panel
The joy of building your own system isn't just about utility. The clear acrylic window lets you show off your work.
- CORSAIR Obsidian Series 250D - tower - mini ITX
- Product Type
- System cabinet
- Form Factor
- Tower
- Black
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- Mini-ITX
- System Cabinet Features
- Windowed top panel, aluminium front panel
- Power Device
- No power supply (ATX)
- 27.7 cm x 35.1 cm x 29 cm
- 11.7 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
- Black
- Cooling System
- Front: 140 mm fan x 1 , Side: 120 mm fan x 1 , Rear: 80 mm fan mount x 1
- CPU Cooler Max Height
- 95 mm
- Video Card Max Length
- 290 mm
- Power Supply Max Length
- 180 mm
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 2.5" / 3.5" shared , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 2
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 27.7 cm
- 35.1 cm
- 29 cm
- 11.7 kg
- Limited warranty - 2 years
