Corsair Memory TX650 V2 650W ATX Enthusiast Series
Quicklinx: 7CHBWS00 Mfr#: CP-9020038-UK
Compatible with 4th generation Intel® Core™ series processors
Designed to deliver the clean, stable power your system deserves
When you build or upgrade your own system, you want a power supply that meets both your power requirements and your exacting standards for performance and noise. The entire Enthusiast Series TX V2 family has been designed to do just that. With any TX V2 PSU, you'll find the right balance between price and the features you want: high efficiency, tight voltage regulation, low ripple and noise, and thermally-controlled fan speed.
Unlike many "value-oriented" power supplies, the entire range of TX V2 power supplies are designed to continuously deliver their rated power, all the way to 50°C ambient temperature. And with the tight voltage regulation and low ripple and noise that Corsair's Enthusiast Series in known for, you'll get clean power too. No more random crashes caused by dirty or insufficient power!
All TX V2 power supplies deliver up to 85% efficiency, feature a single +12V rail for simple installation, and are compatible with the latest Intel and AMD platforms, as well as NVIDIA® and AMD multi-GPU configurations. They are even ErP ready, so your system can use as little as 1W of power in standby mode (when used with an ErP-compliant motherboard).
CORSAIR Enthusiast Series TX650 V2 - power supply - 650 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.31/ EPS12V 2.92
80 PLUS Certification
80 PLUS Bronze
2.2 kg
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
+3.3V - 30 A , +5V - 30 A , +12V - 53 A , -12V - 0.8 A , +5VSB - 3 A
Output connectors
1 x power 24 pin ATX , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 2 x 6 pin PCI Express power , 8 x 4 PIN internal power , 8 x 15 pin Serial ATA power , 2 x 4 PIN mini-power connector
Cooling System
140 mm fan
15 cm x 16 cm x 8.6 cm
5-year warranty
PSU Form Factor
ATX
United Kingdom
Input Voltage
AC 90-264 V
Output Voltage
+3.3, +5, ±12 V
Power Capacity
650 Watt
Output Current
80 PLUS Bronze
MTBF
100,000 hours
Cooling System
140 mm fan
Over current protection, over voltage protection, undervoltage protection, short-circuit protection, single 12V rail, dual ball bearing cooling fan, non-modular
FCC Class B certified, UL, TUV, C-Tick, cUL, CB, CCC, cTUVus
Limited warranty - 5 years
15 cm
16 cm
8.6 cm
2.2 kg
Shipping Width
21.6 cm
Shipping Depth
29 cm
Shipping Height
13 cm
Shipping Weight
3 kg
