The Graphite Series 760T full-tower PC case starts with a visually stunning design that's a match for its stunning performance potential.
The beauty begins on the outside with its sculpted shapes and ingenious, full windowed hinged side panels with flush-mount latches. The front panel has two massive 140 mm intake fans bathed in soft LED light, and there's a dual-speed fan selector for performance or silence. Inside, there's ample cooling potential, with eight fan mounting locations and room for multiple radiators for self-contained liquid CPU coolers, or even custom liquid cooling. And, clever touches like modular drive cages and laterally mounted SSD bays maximize interior volume to help your high-performance dreams come true.
Swing-out side panels
The side panels are hinged, so opening your 760T is as simple as pulling the flush-mounted latch. They can also be removed entirely by simply lifting them off of the hinges. -
Ample cooling potential
Like all Corsair cases, the 760T is designed for high-performance system builds, and high-performance systems require sophisticated cooling. There are eight total fan mounts, with room for top, front, bottom and rear-mounted radiators. -
A clever drive bay design that maximizes interior volume
The four SSD bays are mounted laterally to make the most efficient use of the interior space. The combo 3.5"/2.5" drive bays employ a modular bay system, so you can remove the bays you don't need. The end result is an open interior optimized for extra-long GPUs and free airflow. -
Front I/O panel with USB 3.0 and USB 2.0 connectors
You can never have too many devices. The 760T front panel has two high-speed USB 3.0 connectors and two USB 2.0 connectors, plus headphone and microphone connectors for your headset. -
Dual LED front intake fans with dual-speed control
The fans are custom-engineered by Corsair to deliver high-volume airflow with less noise and turbulence. The extra-large diameter allows them to run at a lower RPM, and they're positioned to deliver cool air directly to your GPUs. A front panel switch allows you to toggle between silent and performance modes.
- CORSAIR Graphite Series 760T - tower - XL-ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Arctic white
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone , 2 x USB 2.0
- Supported Motherboards
- ATX, microATX, Mini-ITX, Extended ATX, XL-ATX
- System Cabinet Features
- Screwless drive bays, fan speed controller, front dust filter, cable management holes, modular HDD brackets, screwless side panels, supports 120 mm radiator in bottom, supports 120/140 mm radiator in rear, supports 240/280 mm radiator in front panel, supports 240/280/360 mm radiator in top
- Power Device
- No power supply (ATX)
- 24.6 cm x 56.8 cm x 56.4 cm
- 11.2 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- XL-ATX
- Internal Bays Qty
- 10
- Front Accessible Bays Qty
- 3
- Product Material
- Steel
- Arctic white
- Cooling System
- Front: 140 mm fan x 2 / intake / white LED , Rear: 140 mm fan x 1 / 1 x 120/140 mm fan supported , Top: fan mount x 1 / 2 x 140 mm fan or 3 x 120 mm fan supported , Bottom: 120 mm fan mount x 1
- CPU Cooler Max Height
- 170 mm
- Video Card Max Length
- 450 mm
- Power Supply Max Length
- 240 mm
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" , 6 (total) / 6 (free) x internal - 2.5" / 3.5" shared , 4 (total) / 4 (free) x internal - 2.5"
- Expansion Slots
- 9
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 2 x USB 2.0
- Power Device
- No power supply
- Specification Compliance
- ATX
- 24.6 cm
- 56.8 cm
- 56.4 cm
- 11.2 kg
- Limited warranty - 2 years
