With immaculate tempered glass enclosing the entire chassis, every component of your build is on display for all to see, including three vivid RGB LED fans and a built-in LED controller. Room for a few case fans, and fully compatible with radiators. Removable fan trays in the front and top of the chassis allow for additional space or mounting cooling outside of the chassis.
Four-panel tempered glass on every side of the case
The extremely beautiful case Corsair has made. With tempered glass enclosing the entire chassis, every component of your build is on display for all to see. -
Direct airflow path to keep your CPU and GPU running cooler
Light up your build with brilliant LED effects. Three RGB LED fans and LED controller keeps your components running cool. -
Room for practically anything
Create as much space as you want with room for a few case fans, virtually every-size radiator or by removing fan trays. -
Cable management made simple
Cable routing channels with velcro cable straps for clean cable management.
- CORSAIR Crystal Series 570X RGB - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- White
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Top panel dust filter, front dust filter, rear dust filter, supports 120 mm radiator in rear, supports 120/240 mm radiator in top, RGB illumination, supports 120/240/280/360 mm radiator in front panel
- Power Device
- No power supply (ATX)
- 23.4 cm x 48 cm x 51.2 cm
- 10.9 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 4
- Product Material
- Steel, tempered glass
- White
- Cooling System
- Front: 120 mm fan x 3 / 2 x 140 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1
- CPU Cooler Max Height
- 170 mm
- Video Card Max Length
- 370 mm
- Power Supply Max Length
- 225 mm
- Expansion Bays
- 2 (total) / 2 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 23.4 cm
- 48 cm
- 51.2 cm
- 10.9 kg
- Limited warranty - 2 years
