Corsair Carbide series PC cases have the high-end features you need, and nothing you don’t. Designed to be the foundation of awesome yet approachable gaming PCs, they combine the advanced technology and ergonomic features, lots of room to build and expand, and amazing cooling potential.
- CORSAIR Carbide Series SPEC-ALPHA - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- White, red
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Fan speed controller, front dust filter, rear dust filter
- Power Device
- No power supply (ATX)
- 22 cm x 51.8 cm x 47.4 cm
- 5.7 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 7
- White, red
- Cooling System
- Front: 120 mm fan x 2 / LED , Top: 120 mm fan mount x 2 , Rear: 120 mm fan x 1
- CPU Cooler Max Height
- 156 mm
- Video Card Max Length
- 380 mm
- Power Supply Max Length
- 190 mm
- Expansion Bays
- 3 (total) / 3 (free) x internal - 3.5" , 4 (total) / 4 (free) x internal - 2.5"
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 22 cm
- 51.8 cm
- 47.4 cm
- 5.7 kg
- Limited warranty - 2 years
