High airflow.
Small size.
Huge potential.
If you're building a compact gaming rig with a MicroATX board, you've found something special. The SPEC-M2 features excellent cooling and great expansion options. Modern features like USB 3.0 and SSD compatibility, room for full sized graphics cards and PSUs, and an oversized side panel window mean your next rig can look expensive – even if it's not.
Compact high airflow design
With a full mesh front panel and direct airflow path to the GPU, the SPEC-M2 gets cool air directly to your hottest components with nothing in between.
Great cooling options
A front LED 120mm fan gets your cooling off the ground, and extra mounts provide more expandability. Take advantage of the 240mm front radiator support to upgrade your CPU or GPU to liquid cooling.
A modern design, inside and out
There's a USB 3.0 front panel port for the latest high-speed peripherals. Inside, there are built-in mounts for dual high-performance 2.5" SSD drives, and 3.5" and 5.25" drive installation is tool-free. Cable routing channels and cutouts simplify builds and improve aesthetics.
Flush-mounted side panel window
Showcase your powerful components. And when you want to get at them, the thumbscrews let you get quick access without looking for a screwdriver.
With a full mesh front panel and direct airflow path to the GPU, the SPEC-M2 gets cool air directly to your hottest components with nothing in between. -
A front LED 120 mm fan gets your cooling off the ground, and extra mounts provide more expandability. Take advantage of the 240 mm front radiator support to upgrade your CPU or GPU to liquid cooling. -
There's a USB 3.0 front panel port for the latest high-speed peripherals. Inside, there are built-in mounts for dual high-performance 2.5" SSD drives, and 3.5" and 5.25" drive installation is tool-free. Cable routing channels and cutouts simplify builds and improve aesthetics. -
- CORSAIR Carbide Series SPEC-M2 - tower - micro ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- I/O Connectors
- 1 x USB 3.0 , 1 x headphones , 1 x microphone , 1 x USB 2.0
- Supported Motherboards
- microATX, Mini-ITX
- System Cabinet Features
- Front dust filter, supports 240 mm radiator in front panel, supports 120 mm radiator in rear, bottom dust filter
- Power Device
- No power supply (ATX)
- 19.8 cm x 44.8 cm x 37.8 cm
- 4.8 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Micro ATX
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 1
- Cooling System
- Rear: fan mount x 1 / 2 x 120 mm fan supported , Top: fan mount x 1 / 2 x 120 mm fan supported , Front: 120 mm fan x 1 , Front: fan mount x 1 / 1 x 120 mm fan supported
- CPU Cooler Max Height
- 150 mm
- Video Card Max Length
- 383 mm
- Power Supply Max Length
- 160 mm
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 4
- 1 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack , 1 x USB 2.0
- Power Device
- No power supply
- Specification Compliance
- ATX
- 19.8 cm
- 44.8 cm
- 37.8 cm
- 4.8 kg
- Limited warranty - 2 years
