Elegant external design meets precise acoustic engineering in a perfect blend of beauty, power, and quietness. The 600Q is built to keep your PC whisper-quiet, no matter what's running inside. Sound-damping material is built into the solid steel front, top and side panels, and the three-speed fan controller lets you pick your optimal noise and cooling performance levels.
Elegant and functional
600Q's gorgeous external looks conceal an equally beautiful internal layout. Secure your cables with cleverly-positioned tie downs and routing grommets. Cleanly house the PSU and drive bays behind removable covers, optimally positioned to increase direct airflow - and decrease fan usage. -
Simplicity and fun
It's easy to add drives, route cables, and get your system assembled just the way you want it. Spend less time building, and more time actually enjoying your PC. -
Cool means quiet
600Q's inverse ATX case design brings cool air directly to the components by eliminating obstruction from extra, unused drive bays. Natural airflow keeps fan noise to a minimum. Need big-time cooling for the powerful PC components? 600Q includes a variety of factory fan mounting positions, making it simple to step up to liquid CPU and GPU coolers. -
Inverse ATX layout
With this layout, airflow is easily directed at the hottest devices in your system; the GPU and CPU, and not wasted on drive cages. -
Sound damping throughout
Keep your system quiet and cool with high-density sound damping material on both side panels, the front panel, and top panel. It's so quiet, you'll find yourself wondering if your PC is even powered on. -
Steel exterior
Get rid of those plastic cases - the 600Q has full steel exterior panels for extra durability and gorgeous good looks. -
Three included fans
Great airflow doesn't have to be noisy - the inbuilt fans can push good amounts of air across your hottest devices without that annoying fan hum, and the three-speed fan controller lets you decide exactly how fast they run. -
PSU and bay cover
Clean up the inside of your case by tucking all those cables and less-attractive drives behind a clean, refined PSU and a bay cover. Or remove them for assembly - it's up to you. -
Easy to clean
Easily access dust filters on front and bottom mean you'll never spend more than a minute getting dust out of your system. -
Easy to build
Tool-free drive installation, side panel access, and tons of cable routing variants and tie downs means you can spend less time building your PC and more time using it.
- CORSAIR Carbide Series Quiet 600Q - tower - extended ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- I/O Connectors
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX, Extended ATX
- System Cabinet Features
- Fan speed controller, front dust filter, bottom dust filter
- Power Device
- No power supply (ATX)
- 26 cm x 45.4 cm x 53.5 cm
- 10 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Extended ATX
- Internal Bays Qty
- 5
- Front Accessible Bays Qty
- 2
- Cooling System
- Front: 140 mm fan x 2 , Bottom: 120 mm fan mount x 3 / 3 x 120 mm or 2 x 140 mm fan supported , Rear: 140 mm fan x 1 , Front: 120/140 mm fan mount x 2
- CPU Cooler Max Height
- 200 mm
- Video Card Max Length
- 395 mm
- Power Supply Max Length
- 210 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
- Expansion Slots
- 8
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 26 cm
- 45.4 cm
- 53.5 cm
- 10 kg
- Limited warranty - 2 years
