The unconventional design of Carbide Series Air 540 utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, and memory without your drives or power supply getting in the way. And, you can mount up to six 120 mm or five 140 mm fans, with 280 mm top radiator support and room for a 360 mm radiator on the front panel.
Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. The tinted, oversized flush-mount side window lets you show off your work.
Outstanding cooling
The Direct Airflow Path design utilizes dual chambers to deliver cooler air to your CPU, graphics cards, motherboard, memory, and other PCI-E components without your drives or power supply getting in the way. -
Ideal for advanced air cooling and water cooling
You can mount up to six 120 mm or five 140 mm fans, or install a 240 mm or 280 mm top radiator and a 240 mm, 280 mm, or even 360 mm radiator on the front panel. Corsair's innovative cable routing system gives you more options for hiding pumps and tubing out of the way. -
Built for builders
Like all Corsair cases, Carbide Series Air 540 is designed for fast, neat, and satisfying builds. You get tool-free PCI-E and storage installation, two internal hot-swap drive bays, and more features for making assembly, upgrades, and maintenance quick and easy. And, the tinted, oversized flush-mount side window lets you show off your work.
- CORSAIR Carbide Series Air 540 - Silver Edition - tower - extended ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Silver
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX, Extended ATX
- System Cabinet Features
- Screwless drive bays, front dust filter, cable management system, Direct Airflow Path design
- Power Device
- No power supply (ATX)
- 41.5 cm x 33.2 cm x 45.8 cm
- 7.4 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Extended ATX
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 2
- Hot-Swap Bays Qty
- 2
- Product Material
- Steel, acrylic
- Silver
- Cooling System
- Front: 140 mm fan x 2 / intake / white LED , Rear: 140 mm fan x 1 / exhaust , Top: 120/140 mm fan mount x 2
- CPU Cooler Max Height
- 170 mm
- Video Card Max Length
- 320 mm
- Power Supply Max Length
- 250 mm
- Expansion Bays
- 4 (total) / 4 (free) x internal - 2.5" , 2 (total) / 2 (free) x hot-swap - 2.5" / 3.5" shared , 2 (total) / 2 (free) x front accessible - 5.25"
- Expansion Slots
- 8
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 41.5 cm
- 33.2 cm
- 45.8 cm
- 7.4 kg
- Limited warranty - 2 years
