Corsair Carbide Series 330R Blackout Mid-Tower Gaming Case
Quicklinx: B60RWS00 Mfr#: CC-9011076-WW
The Carbide Series 330R starts with the award-winning original 330R, and adds a black anodized front panel with a three-speed fan controller.
It's designed for systems that will go into media rooms, bedrooms, dorm rooms, or any place where both silence and performance are essential. Sound damped doors and panels and clever intake fan design are combined with generous expansion room and builder-friendly features to allow you to build a silent PC that can pack a lot of power for gaming and high-definition media streaming.
  • Superior sound absorption
    The top panel, black anodized front panel, and side doors are all lined with noise damping material, and the cleverly designed front intakes help reduce fan noise.
  • Smart airflow design
    The 330R Blackout Edition incorporates a direct path between the included 140mm fan and your CPU and GPU, providing cold air directly to the hottest components with less restriction and less noise.
  • Five fan mount locations with three-speed controller
    An intake and exhaust fan are included, and you can go from there by installing two 120 mm or 140 mm fans in the front, and two 120 mm or 140 mm fans on the top panel. It's easy to select the optimal cooling level with the front panel three-speed fan controller.
  • Front panel USB 3.0
    Exploit the screaming speed offered by modern peripherals, and still enjoy backward USB 2.0 compatibility.
  • Built for system builders
    Like all Corsair cases, Carbide Series 330R is designed for fast, neat, and satisfying builds. You get tool-free storage installation, our innovative cable-routing system, easy access low-restriction dust filters, and more features for making assembly, upgrades, and maintenance quick and easy.
CORSAIR Carbide Series 330R Ultra-Silent - Blackout Edition - tower - ATX
System cabinet
Tower
Anodised black brushed aluminium
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Noise reduction, screwless drive bays, front panel door, cable management system, supports 120 mm radiator in rear, supports 240/280 mm radiator in top
No power supply (ATX)
49.5 cm x 21 cm x 48.4 cm
6.8 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
3
Product Material
Steel
Cooling System
Rear: 120 mm fan x 1 / exhaust , Front: 140 mm fan x 1 / intake , Front: fan mount x 1 / 1 x 120/140 mm fan supported , Top: fan mount x 1 / 2 x 120/140 mm fan supported
CPU Cooler Max Height
160 mm
Video Card Max Length
450 mm
Power Supply Max Length
240 mm
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
49.5 cm
21 cm
48.4 cm
6.8 kg
