Corsair Carbide Series 300R Gaming Case
Quicklinx: 800KWS00 Mfr#: CC-9011014-WW
The Corsair Carbide Series: Everything You Need, Nothing You Don't.
The front panel includes two USB 3.0 connectors and audio connectors.
A compact expression of Corsair's gaming philosophy.
Great systems start with a great case, and Carbide Series 300R provides a remarkable number of features in a compact chassis. Easy access, lots of room for expansion, and superior cooling make the 300R a great choice for building powerful PCs that don't take up a lot of room.
Serious cooling potential.
The 300R is equipped with two fans for intake and exhaust, and the integrated dust filters on the front and bottom intakes are easy removable. There's room for you to install five more fans, including mounting points for two side panel 120mm fans for drawing cool air directly over your GPUs. If you're building a multi-GPU gaming rig, proper graphics ventilation is essential.
High-performance gaming systems need room to work with. The compact 300R delievers the room you need to build your ultimate gaming PC.
It's big where it counts.
Despite its size, the 300R can fit extra-long graphics cards of up to 450mm length, and it has three optical drive bays and four hard drive bays. All the bays all tool-free, and the hard drive bays have integrated support for 2.5" drives, so you won't need to deal with adapters when installing SSDs
Build quality.
Whether you're building multiple systems or just one, and whether you're a professional or if it's your very first build, the 300R has the smart features that matter. Just like the drive bays, the side panels are tool-free, so you'll spend less quality time with your screwdriver.
The black painted interior has a CPU cutout for quick installing or upgrading of CPU heatsinks, and Corsair's innovative cable management system provides a straightforward way to route cables behind the motherboard, not across it where it can interfere with airflow and give your system a cluttered look.
Contents and Specifications
Package contents
  • Carbide Series 300R
  • Quick Start Guide
  • Installation kit
Technical Specifications
  • Three 5.25 drive bays
  • Four3.5 hard drive bays with 2.5 compatibility
  • Seven expansion slots
  • Two-year warranty
  • Front I/O panel contains:
    • Two USB 3.0 connectors
    • 3.5 headphone and microphone connector
    • Power and reset switches
  • Dimensions: 19.1 x 8.3; x 17.7
  • Supports graphics cards up to 450mm in length
  • Two 120mm/140mm top fan mount locations
  • Two side panel 120/140mm fan mount locations
  • Two front panel 120/140mm fan mount locations
  • Includes one front-mounted 140mm fan and one rear 120mm fan
Compatibility
  • ATX and Micro ATX motherboards
Product Features
  • Room for graphics cards up to 450mm long.
  • USB 3.0 front panel connectors.
  • Built-in compatibility for SSDs in the four hard drive bays gives you the flexibility you need.
  • Keep your system cool with up to 7 fan mount locations.
  • Easily accessible dust filters keep the cool air flowing over your valuable components.
  • Install or upgrade your CPU heatsink quickly with the easy-access backplate cutout.
  • Optimize airflow and keep your system neat and tidy using the intelligent cable management system.
  • Dimensions: 19.1" x 8.3" x 17.7"
  • Material: Steel and plastic
  • Color: Black
  • Model: CC-9011014-WW
  • Drive Bays: (x3) 5.25" / (x4) 3.5"/2.5" Drive Caddies
  • Cooling: (x1) 140mm Intake fan / (x1) 120mm Exhaust Fan
  • Expansion Slots: 7 - Motherboard: ATX, mATX - Front I/O: (x2) USB 3.0, (x1) Headphone, (x1) Mic
  • Power Supply: ATX (not included)
Box Contents
  • Corsair Carbide Series 300R case
  • Accessory kit
  • Quick Start Guide
This case does NOT include the USB 3.0 to USB 2.0 Adaptor cable
  • A compact expression of Corsair's gaming philosophy
  • Serious cooling potential
    The 300R is equipped with two fans for intake and exhaust, and the integrated dust filters on the front and bottom intakes are easy removable. There's room for you to install five more fans, including mounting points for two side panel 120 mm fans for drawing cool air directly over your GPUs. If you're building a multi-GPU gaming rig, proper graphics ventilation is essential.
  • It's big where it counts
    Despite its size, the 300R can fit extra-long graphics cards of up to 450 mm length, and it has three optical drive bays and four hard drive bays. All the bays are tool-free, and the hard drive bays have integrated support for 2.5" drives, so you won't need to deal with adapters when installing SSDs.
  • Build quality
    Whether you're building multiple systems or just one, and whether you're a professional or if it's your very first build, the 300R has the smart features that matter. Just like the drive bays, the side panels are tool-free, so you'll spend less quality time with your screwdriver. The interior has a CPU cutout for quick installing or upgrading of CPU heatsinks, and Corsair's cable management system provides a straightforward way to route cables behind the motherboard, not across it where it can interfere with airflow and give your system a cluttered look.
CORSAIR Carbide Series 300R - tower - ATX
System cabinet
Tower
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Screwless drive bays, front dust filter, bottom dust filter
No power supply (ATX)
21 cm x 48.5 cm x 44.9 cm
7.21 kg
Tower
Max Mainboard Size
ATX
Internal Bays Qty
4
Front Accessible Bays Qty
3
Product Material
Steel
Cooling System
Side: 120/140 mm fan mount x 2 , Top: 120/140 mm fan mount x 2 , Front: 120/140 mm fan mount x 1 , Front: 140 mm fan x 1 , Rear: 120 mm fan x 1
CPU Cooler Max Height
170 mm
Video Card Max Length
450 mm
Power Supply Max Length
240 mm
Expansion Bays
3 (total) / 3 (free) x internal - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
Expansion Slots
7 x Expansion Slot
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
21 cm
48.5 cm
44.9 cm
7.21 kg
Resources
The following resources are available for the Corsair Carbide Series 300R Gaming Case
