The Carbide Series 100R Mid Tower case has the versatility serious PC builders need with the clean, modern exterior design all users can agree with. Tool-free access to the interior, a flush-mounted window for admiring your components, and a range of cooling options are all available to the home builder at a spectacular value with this latest addition to the Corsair family.
Simple, elegant, and sharp
It's the performance PC platform in stealth mode. With a mesh-free front panel, flush-mounted side panel window and clean lines, the 100R is both professional enough for the office and customizable enough for any home PC build. -
Storage, simplified
The simplicity begins with tool-free 3.5" and 5.25" drive installation, and all four hard drive trays provide solid-state drive support so you can mix and match to fit your needs. On the outside, dual USB 3.0 front panel ports give you quick and easy access to the latest high-speed portable hard drives and flash drives. -
Creative cooling
Five internal fan mounts let you customize your cooling to match your build. The case is designed to draw airflow directly to the GPU to help ensure that you and your graphics card will both keep your cool during intense gaming sessions. -
The features that builders want
Whether you're building one system or a dozen, you want the attention to detail that makes it easy. You'll appreciate things like cable routing channels for easy cable organization and better-looking builds, and the side panels are attached with thumbscrews so you can get in and out without hunting for a screwdriver.
- CORSAIR Carbide Series 100R - Silent Edition - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Screwless drive bays, fan speed controller, cable management holes, screwless side panels
- Power Device
- No power supply (ATX)
- 20 cm x 47.1 cm x 43 cm
- 4.8 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 4
- Front Accessible Bays Qty
- 2
- Product Material
- Steel
- Cooling System
- Front: 120 mm fan mount x 1 , Top: fan mount x 1 / 2 x 120 mm fan supported , Rear: 120 mm fan x 1 / exhaust , Front: fan mount x 1 / 1 x 120/140 mm fan supported
- CPU Cooler Max Height
- 150 mm
- Video Card Max Length
- 414 mm
- Power Supply Max Length
- 260 mm
- Expansion Bays
- 2 (total) / 2 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 2.5" / 3.5" shared
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 20 cm
- 47.1 cm
- 43 cm
- 4.8 kg
- Limited warranty - 2 years
