Corsair Carbide Clear 400C Carbide Series Compact Mid-Tower Case
Quicklinx: C5J1WS00 Mfr#: CC-9011095-WW
The Carbide Clear 400C packs all the performance and expandability you need into a beautifully compact case design. Put your components on display through the gorgeous, full-size window panel that opens with a touch - and keep it all running cool and quiet with Direct Airflow technology.
  • Clean, modern lines with an all steel exterior.
  • Full side panel window to see your internal parts, complete with tool-free latch and hinge for easy access.
  • Compact Mid Tower design fits full sized ATX boards and multiple graphics cards.
  • Direct air flow access to the hottest components with no drive cages in the way.
  • Capable liquid cooling support for both CPU and GPU loops.
  • Included AF140L and AF120L fans for excellent performance and low noise levels.
  • PSU and 3.5h modular covers conceal cables and drives, and can be relocated or removed entirely for easy assembly.
  • Full dust filtration on bottom, front, and top.
  • Tons of cable-routing options and tie downs so cables can be easily tucked out of the way.
  • Tool-free drive installation for quick builds.
  • Front radiator compatibility for up to a single 360mm radiator or multiple 120/140mm radiators.
  • Easy to build, hard to beat
    With a one-touch side panel, tool-free drive installation, and three-point dust filter access, 400C is easy to build and even easier to keep clean. You'll spend less time on setup and maintenance, and more time enjoying your PC.
  • Hinged and latched full side panel window
    Easily access your components with a single touch - and when it's closed, enjoy viewing every part of your build through the full side panel window.
  • Clean, modern lines with an all-steel exterior
    Get rid of those plastic cases - the 400C has full steel front and top panels for extra durability and gorgeous good looks.
  • Direct Airflow technology
    One way to reduce noise is to make sure your fans don't work harder than they have to. By removing the drive cages behind the intake fans, the 400C case provides a more efficient direct airflow path to your hottest components, the CPU and GPU.
  • Compact design, full-size capabilities
    Don't let the compact dimensions of the 400C fool you. It can house a full ATX motherboard and multiple GPUs.
  • Two included fans
    Great airflow doesn't have to be noisy - the inbuilt fans can push good amounts of air across your hottest devices without that annoying fan hum, and the direct airflow design of the 400C provides an excellent path for cold air to get to the hottest parts.
  • PSU and bay covers
    Clean up the inside of your case by tucking all those cables and less-attractive drives behind two modular, clean, and refined PSU and bay covers. Or remove them for assembly - it's up to you.
  • Easy to clean
    Easy-to-access dust filters on front, top, and bottom mean you'll never spend more than a minute getting dust out of your system.
CORSAIR Carbide Series Clear 400C - tower - ATX
System cabinet
Tower
Windowed Side Panel
White
I/O Connectors
2 x USB 3.0 , 1 x headphones , 1 x microphone
Supported Motherboards
ATX, microATX, Mini-ITX
System Cabinet Features
Top panel dust filter, front dust filter, Direct Airflow Path design, bottom dust filter
No power supply (ATX)
21.5 cm x 42.5 cm x 46.4 cm
8.2 kg
Tower
Windowed Side Panel
Max Mainboard Size
ATX
Internal Bays Qty
5
Product Material
Steel, acrylic
White
Cooling System
Front: 140 mm fan x 1 , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan x 1 , Front: 120 mm fan mount x 3 / 3 x 120 mm or 2 x 140 mm fan supported
CPU Cooler Max Height
170 mm
Video Card Max Length
370 mm
Power Supply Max Length
190 mm
Expansion Bays
2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
Expansion Slots
7
2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
No power supply
Specification Compliance
ATX
21.5 cm
42.5 cm
46.4 cm
8.2 kg
