Carbide series 270R is compact and engineered for building high-performance yet minimalist systems.
Look hot, run cold
Take advantage of direct airflow cooling as well as ample room for radiators in the front, top and rear. Keep your rig running cool and quiet with 270R's enormous cooling potential. -
Keep it clean
Unobstructive exterior panels provide an understated look for an overall clean and minimalist design. The subtle cable routing compartment makes it even easier to achieve an effortlessly clean build.
- CORSAIR Carbide Series 270R Windowed - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Front dust filter, rugged, Direct Airflow Path design, supports 120 mm radiator in rear, PSU dust filters, supports 120/240 mm radiator in top, supports 120/240/280/360 mm radiator in front panel
- Power Device
- No power supply (ATX)
- 21 cm x 50.9 cm x 46 cm
- 7.28 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 4
- Product Material
- Steel
- Cooling System
- Front: 120 mm fan x 1 / red LED , Rear: 120 mm fan x 1 , Front: 120/140 mm fan mount x 3 / 3 x 120 mm or 2 x 140 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1
- CPU Cooler Max Height
- 170 mm
- Video Card Max Length
- 370 mm
- Power Supply Max Length
- 225 mm
- Expansion Bays
- 2 (total) / 2 (free) x internal - 3.5" , 2 (total) / 2 (free) x internal - 2.5"
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Included Accessories
- Accessory kit
- Power Device
- No power supply
- Specification Compliance
- ATX
- 21 cm
- 50.9 cm
- 46 cm
- 7.28 kg
- Limited warranty - 2 years
