Build a computer using the Corsair Obsidian 800D Chassis: Part 1
Build a computer using the Corsair Obsidian 800D Chassis: Part 2
The Obsidian series 800D is built to last through years of motherboard, power, memory, cooling, and component upgrades.
The steel structure has a matte coating both inside out and is finished with a brushed aluminum faceplate for a professional look that's both serious and awe-inspiring. A windowed side panel makes it easy to show off your work.
Designed for years of performance
The Obsidian series 800D is built to last through years of motherboard, power, memory, cooling, and component upgrades. The steel structure has a matte coating both inside out and is finished with a brushed aluminum faceplate for a professional look that's both serious and awe-inspiring. A windowed side panel makes it easy to show off your work. -
Three isolated cooling zones
The power supply compartment, main compartment and the SATA bays each have dedicated cooling subsystems to prevent heat buildup. A dust-filtered fan draws in cold air at the bottom of the chassis and exhausts it at the rear and top. This clever design forces fresh air directly over the graphics card and CPU. The SATA hot-swap bays are cooled by a separate fan which vents from the chassis via a sealed chamber and prevents the heat generated by the drives from entering the main compartment. The power supply compartment has its own dedicated intake and exhaust, also isolated from the main compartment. -
Advanced features for extreme flexibility
A four-drive SATA hot-swap drive bay sits in the front of the case, making it easier to install or swap hard drives on the fly. A unique cable routing system virtually eliminates cable clutter that can impede airflow. The tool-free design allows for easy entry, easy access, and quick installation of 5.25" drives.
- CORSAIR Obsidian Series 800D - tower - extended ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- I/O Connectors
- 4 x USB 2.0 , 1 x FireWire , 1 x headphones , 1 x microphone
- Installed Fans Qty
- 3
- Supported Motherboards
- ATX, microATX, Mini-ITX, Extended ATX
- Server Storage Bays
- SATA - hot-swap
- System Cabinet Features
- Screwless drive bays
- Power Device
- No power supply (ATX)
- 22.9 cm x 60.9 cm x 60.9 cm
- 16.2 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Extended ATX
- Internal Bays Qty
- 2
- Front Accessible Bays Qty
- 5
- Hot-Swap Bays Qty
- 4
- Server Swappable Drive Interface
- SATA
- Product Material
- Steel, brushed aluminium
- Black
- Fans
- Side: 1 x 14 cm - (1 installed) , Rear: 1 x 14 cm - (1 installed) , Bottom: 1 x 14 cm - (1 installed) , Top: 3 x 12 cm - (0 installed)
- CPU Cooler Max Height
- 180 mm
- Video Card Max Length
- 430 mm
- Power Supply Max Length
- 240 mm
- Expansion Bays
- 5 (total) / 5 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x hot-swap - 3.5" , 2 (total) / 2 (free) x internal - 3.5"
- Expansion Slots
- 7 x Expansion Slot
- Power Device
- No power supply
- Specification Compliance
- ATX
- 22.9 cm
- 60.9 cm
- 60.9 cm
- 16.2 kg
- Limited warranty - 2 years
