CX Series modular power supply units are an excellent choice for basic system builds and desktop PC computer upgrades, offering high reliability, low noise, and easy installation. The flexible modular cabling system lets you use only the cables you need, and 80 PLUS Bronze certified efficiency means less excess heat, lower noise, and lower power bills. The large-diameter, thermally controlled fan makes the CX Series modular quieter at idle, and the large diameter reduces noise even when you're pushing your system hard. And, the matte finish, sleeved cables and connectors help give your system a restrained, high-tech look.
Corsair engineering and quality control
Every Corsair power supply is designed by California engineering team and built to exact specifications. The same care that goes into the design and testing of renowned high-power enthusiast power supplies also goes into the CX Series modular, because you need confidence and reliability regardless of your build budget. -
Modular cabling system
Since the peripheral power cables aren't hard-wired to the power supply, you can connect only the cables you need for your exact configuration of PCI-E cards and storage devices. The rest of the cables stay in the box, and not in your PC's case where they can add to the clutter and interfere with airflow. -
Large-diameter, thermally controlled fan
Once you've installed a PSU, you shouldn't have to think about it. Employing a thermally controlled fan makes the CX Series modular quiet at idle, and the large diameter reduces noise even when you're pushing your system hard. -
Black goes with everything
You're building a PC, not a battleship, and appearance counts. The matte black finish and all-black sleeved cables and connectors help give your system a high-tech, restrained look.
- CORSAIR CX-M Series CX750M - 2015 Edition - power supply - 750 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3/ EPS12V 2.91
- 80 PLUS Certification
- 80 PLUS Bronze
- 3.27 kg
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 62 A , -12V - 0.8 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 4 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 2 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- Matte black
- 15 cm x 16 cm x 8.6 cm
- 3-year warranty
- PSU Form Factor
- ATX
- Matte black
- Localisation
- United Kingdom
- Input Voltage
- AC 100-240 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- Efficiency
- 85%
- 80 PLUS Bronze
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Sleeved cables, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, temperature controlled fan, semi-modular
- Energy-Related Products (ErP) Lot 6
- Limited warranty - 3 years
- 15 cm
- 16 cm
- 8.6 cm
- 3.27 kg
- Shipping Width
- 29 cm
- Shipping Depth
- 21.6 cm
- Shipping Height
- 13 cm
- Shipping Weight
- 3.53 kg
