Beautifully simple and engineered to perform: the Crystal 460X has two-panel tempered glass, Direct Airflow cooling technology, is compact, expandable, and with RGB fans, is not afraid of the spotlight.
RGB LED fans
Light up your build with brilliant LED effects and draw ample cool air directly to your components without the turbulence that can cause fan hum. -
Room for activities
Crystal 460X was engineered to pack all the performance and expandability you need into a beautifully modern and compact case design. Put your build on display through beautiful two-panel tempered glass and keep it all running cool and quiet with Direct Airflow technology. -
Style is everything
Make your build stand out from the crowd by coordinating the custom-molded translucent blades with your build for a sleek, brilliant look - all visible through the tempered glass panels. -
Clean, modern lines with an all steel exterior
Get rid of those plastic cases - the 460X has full steel front and top panels for extra durability and gorgeous good looks. -
Direct Airflow Path
Drive cages are moved up and out of the path of cool air from the front intake fans and high-temperature components. -
Minimal setup
With tool-free drive installation and three-point dust filter access, the Corsair Crystal 460X is easy to build - and even easier to keep clean. You'll spend less time on setup and maintenance, and more time enjoying your PC.
- CORSAIR Crystal Series 460X RGB - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Black
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Front dust filter, Direct Airflow Path design, tool-free drive holder, Liquid Cooling Ready, supports 120/240/280/360 mm radiator in front panel
- Power Device
- No power supply (ATX)
- 22 cm x 44 cm x 46.4 cm
- 7.97 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 5
- Product Material
- Steel, tempered glass
- Black
- Cooling System
- Front: 120 mm fan x 3 / intake / 2 x 140 mm fan supported , Top: 120/140 mm fan mount x 2 , Rear: 120 mm fan mount x 1
- CPU Cooler Max Height
- 170 mm
- Video Card Max Length
- 370 mm
- Power Supply Max Length
- 220 mm
- Expansion Bays
- 2 (total) / 2 (free) x internal - 3.5" , 3 (total) / 3 (free) x internal - 2.5"
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 22 cm
- 44 cm
- 46.4 cm
- 7.97 kg
- Limited warranty - 2 years
