The Graphite Series 230T mid-tower PC case has a striking, leading-edge look for building fast systems that look just as fast as they run. The sculpted exterior features dual intake fans bathed in soft, color coordinated LED lighting and a tinted side panel window. Inside, it has the system builder-friendly ergonomics and cooling and expansion flexibility that Corsair is known for. With smart features like dedicated SSD bays and our innovative cable management system, builds, maintenance and upgrades are fast and easy.
Graphite Series 230T is a great choice for gaming PCs, graphics design workstations, or any application where high performance and high style both matter.
- Dual 120mm front LED fans and rear 120mm exhaust fan.
- Tinted, flush-mount side panel window.
- USB 3.0 front panel
- Tool-free SSD, HDD, and ODD installation
- Cable routing and CPU cooler backplate motherboard cutouts
- Seven PCIe slots with thumbscrews and room for GPUs 320mm long
- Install up to four 3.5" and four 2.5" drives simultaneously - tool free.
- Up to six fan mounts for optimal cooling potential
- Dust filters for front and PSU intake.
- Room for up to 200mm ATX PSU (not included)
Box Contents
- Graphite Series 230T case
- Quick Start Guide
- Accessories box with screws, zip ties, and other mounting hardware.
Leading-edge styling
Graphite series cases meet at the intersection of high performance and dramatic design. The front intake fans are bathed in soft LED light, and the sculpted exterior helps you build a fast system that looks fast, too. -
Flexible cooling potential
The 230T comes with dual 120 mm front intake fans with LED lighting, and a rear 120 mm exhaust fan. There's room to add two 120 mm or 140 mm fans on the top, and a 120 mm or 140 mm fan on the bottom. -
Easy system builds, maintenance and upgrades
The side panels, PCI-E expansion slots, and drive bays are all tool-free. Cable routing cutouts are provided for clean-looking builds and better airflow, and there's a CPU cutout to allow for cooling upgrades without removing the motherboard. The intake fan filters help keep dust out of the interior, and they're easy to remove for cleaning. -
Dedicated SSD bays
The 230T offers four 2.5" drive bays for solid-state storage. That's in addition to the four 3.5" bays and three 5.25" optical drive bays. -
Seven PCI-E expansion slots
There's room for multi-GPU setups for powerful gaming systems. The slots are tool-free, so swaps and upgrades are quicker.
- CORSAIR Graphite Series 230T - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Rebel orange
- I/O Connectors
- 2 x USB 3.0 , 1 x headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX, Mini-ITX
- System Cabinet Features
- Screwless PCI card retainers, screwless drive bays, front dust filter, cable management holes, screwless side panels
- Power Device
- No power supply (ATX)
- 21 cm x 50.5 cm x 44 cm
- 6.05 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 8
- Front Accessible Bays Qty
- 3
- Product Material
- Steel
- Rebel orange
- Cooling System
- Front: 120 mm fan x 2 / intake / red LED , Rear: 120 mm fan x 1 / exhaust , Top: 120/140 mm fan mount x 2 , Bottom: 120/140 mm fan mount x 1
- CPU Cooler Max Height
- 165 mm
- Video Card Max Length
- 360 mm
- Power Supply Max Length
- 200 mm
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" , 4 (total) / 4 (free) x internal - 3.5" , 4 (total) / 4 (free) x internal - 2.5"
- Expansion Slots
- 7
- 2 x USB 3.0 , 1 x headphones - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX
- 21 cm
- 50.5 cm
- 44 cm
- 6.05 kg
- Limited warranty - 2 years
