CoolIT ECO ALC 240mm Liquid Cooling
Quicklinx: 73CTWS00 Mfr#: ECO-240
ECO ALC 240 takes liquid cooling to another level. Effectively doubling the surface area of the ECO ALC 120, this solution offers the extra headroom for extreme overclocking that today's gamer demands. Designed for use in tower chassis that supports 240mm radiator, this highly optimized solution procvides maximum cooling at a price point others cant match.
  • Compact liquid cooling solution
  • Universal retention compatible with Intel 775, 1156, 1366 and AMD AM2+/AM3 sockets
  • Micro-channel fluid heat exchanger
  • High efficiency aluminum radiator
  • Designed to operate with four wire fan controlled by motherboard CPU header
Specification
  • CoolIT CPU FHE (Fluid Heat Exchanger)
  • Copper Micro-Channel
  • Universal Retention System
  • Out of the box support provided for Intel 775, 1156, 1366 and AMD AM2, AM2+, AM3 sockets
  • CoolIT Pump; CFF1 Pumps
  • Life Cycle: 50,000 Hour MTBF
  • Long life ceramic bearing pump provides years of reliable, quiet operation
  • CoolIT Radiator: 240mm Class Aluminum Radiator; 275mm (length) x 122mm (width) x 27mm (depth)
  • Custom engineered for low noise and high heat dissipation
  • CoolIT Fan: Dual 120mm Class Fans, 1900 RPM Peak; 120mm (length) x 120mm (width) x 25mm (depth)
  • 4 Wire, Sleeve Bearing, 12Vdc
  • CoolIT CPU Thermal Grease; CooIT Systems Pro A.T.C. (Advanced Thermal Compound)
  • CoolIT 2 Year Manufacturer Warranty
Water Cooling
