Cooler Master VS series power units are 80 PLUS Gold certified, designed for PC gamers and performance enthusiasts. Thanks to Cooler Master exclusive 3D circuit design it offers high efficiency, low crosstalk, and improves the heat dissipation. The modular cable system design with flat-ribbon cables makes cable management a breeze and results in a clean and tidy build. It uses the high grade Japanese capacitor which ensures and extended lifetime and excellent holdup times, in case of power fluctuation.
Less cables, less clutter
VSM power supplies feature a design that allows you to only connect cables that your system needs. Fewer cables mean less mess and better airflow inside your case. -
Quality you can see
VSM PSUs feature high quality Japanese capacitors for many benefits including increased longevity, reduced ripple and electrical instabilities, and better efficiency and protection. -
Compact power
At only 140 mm (5.5 inches) long, VSM PSUs are compact, but are still in the standard ATX form factor. Its size is ideal for mini-ITX builds in cases like Cooler Master's Elite 130. -
80 PLUS savings
With VSM's 80 PLUS Gold certification, enjoy great savings on your energy bill with over 90% efficiency. -
Power chart
Powerful single +12 V rail provides superior load balancing and graphics card compatibility.
- Cooler Master VSM Series V750 - power supply - 750 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31
- 80 PLUS Certification
- 80 PLUS Gold
- Localisation
- United Kingdom
- Input Voltage
- AC 90-264 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- +3.3V - 25 A , +5V - 22 A , +12V - 62 A , -12V - 0.3 A , +5V - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 8 x 15 pin Serial ATA power , 6 x 4 PIN internal power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.6 cm
- 5-year warranty
- ATX12V 2.31
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 90-264 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 750 Watt
- Output Current
- Efficiency
- 90%
- 80 PLUS Gold
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, single 12V rail, DC-DC technology
- UL, TUV, BSMI, CCC, FCC, KCC, EAC, RCM
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 15 cm
- 14 cm
- 8.6 cm
