CoolerMaster Silencio FP120 (120mm) 800-1400rpm PWM Case Fan
Quicklinx: B5HMWS00 Mfr#: R4-SFNL-14PK-R1
The great Cooler Master Silencio FP series introduces desired features to the 120 mm cooling fan offerings. Thanks to its Loop Dynamic Bearing (LDB), the life expectancy is pushed up to an incredibly long hours. Silencio FP’s exclusive driver IC assists in making the fan produce ultra-low vibrations and noise while saving more power with very low energy requirements. Its Smart Fan Engine prevents damage with fan jam detection and protection.
Cooler Master Silencio FP 120 PWM - case fan
Case fan
Package Content
3-pin plug to 4-pin Molex adapter, 4 anti-vibration screws, 4 screws
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Loop dynamic bearing
Rotation Speed
800-1400 rpm
Air Flow
16.4-44 cfm
Noise Level
6.5 - 14 dBA
Power Connector
4 pin Molex connector
Rated Voltage
12 V
Pulse-width modulation (PWM) support
12 cm x 12 cm x 2.5 cm
158 g
5-year warranty
Case fan
Package Content
12 cm
12 cm
2.5 cm
158 g
Heatsink & Fan
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rotation Speed
800-1400 rpm
Air Flow
16.4-44 cfm
Air Pressure
0.47-1.69 mm
Noise Level
6.5 - 14 dBA
Power Connector
Rated Voltage
12 V
Rated Current
0.03 A
Power Consumption
0.36 W
Mounting Kit
Included
MTBF
160,000 hour(s)
IP6X
Limited warranty: - 5 years
