The Hyper 212 EVO cooling systems are designed and optimized to provide the best user experience and cooling potential for a new generation of processors. The Hyper 212 EVO now features four Cooler Master patented Continuous Direct Contact (CDC) heat pipes that are tightly packed into a flat array on the CPU Cooler base. This acts as a virtual vapor chamber that dissipates a large amount of heat. The aluminum fin structure has been optimized to provide the perfect performance balance between high and low speed fan operations
- Cooler Master Hyper 212 Evo - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, LGA1150 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Long life sleeve bearing
- Rotation Speed
- 600-1600 rpm
- Air Flow
- 24.9-66.3 cfm
- Noise Level
- 9 - 31 dBA
- Power Connector
- 4-pin fan connector
- Heat pipe technology, Pulse-width modulation (PWM) support
- 8 cm x 12 cm x 15.9 cm
- 0.58 kg
- Product Type
- Processor cooler
- 8 cm
- 12 cm
- 15.9 cm
- 0.58 kg
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core i7 , Core i7 Extreme Edition , Core i5 , Core i3 , Core 2 Extreme , Core 2 Quad , Core 2 Duo , Pentium , Celeron , Phenom II , Phenom X3 , Phenom X4 , Athlon II , Athlon , Sempron , Athlon X2
- Heatsink Material
- Aluminium
- Heatsink Dimensions
- 159 mm x 116 mm x 51 mm
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 600-1600 rpm
- Air Flow
- 24.9-66.3 cfm
- Air Pressure
- 0.3-1.7 mm
- Noise Level
- 9 - 31 dBA
- Power Connector
