The N200 is a compact mainstream cases with extensive water cooling support and improved air cooling performance wrapped in subtle and simplistic designs.
The N200 not only supports 120 mm radiators at the back, but is the first mini tower that supports installing 120 mm or even 240 mm radiators in the front of the case! Thanks to an all mesh front panel, 2 high quality Cooler Master XtraFlo fans and large air vents, it boasts excellent cooling performance.
Despite its extremely compact size, the N200 supports 160 mm tall CPU tower coolers, long high end VGAs, including the upcoming HD7990, four 2.5" SSDs and three of 3.5" HDDs.
- Cooler Master N200 - tower - mini ITX / micro ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Midnight black
- I/O Connectors
- 1 x USB 3.0 , 2 x USB 2.0 , 1 x microphone , 1 x audio line-out
- Supported Motherboards
- microATX, Mini-ITX
- System Cabinet Features
- Removable dust filter, meshed front panel, floor dust filter, liquid cooling holes, cable management system, supports 240 mm radiator in front panel
- Power Device
- No power supply (ATX / PS/2)
- 20.2 cm x 44.5 cm x 37.8 cm
- 4.3 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- Mini ITX / micro ATX
- Internal Bays Qty
- 6
- Front Accessible Bays Qty
- 2
- Midnight black
- Cooling System
- Front: 120 mm fan x 1 / 2 x 120 mm fan supported , Rear: 120 mm fan x 1 , Top: 120 mm fan mount x 1
- CPU Cooler Max Height
- 160 mm
- Video Card Max Length
- 355 mm
- Expansion Bays
- 1 (total) / 1 (free) x front accessible - 5.25" , 1 (total) / 1 (free) x front accessible - 3.5" , 2 (total) / 2 (free) x internal - 3.5" , 4 (total) / 4 (free) x internal - 2.5"
- Expansion Slots
- 4
- 1 x USB 3.0 , 2 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX / PS/2
- 20.2 cm
- 44.5 cm
- 37.8 cm
- 4.3 kg
- Limited warranty - 2 years
