CoolerMaster MegaFlow 200 Red LED Fan - 200mm, 700RPM
Quicklinx: 8K37WS00 Mfr#: R4-LUS-07AR-GP
  • High air flow for maximum cooling performance.
  • Quiet operation with low RPM.
  • RoHS compliance for protecting the environment.
  • Compatible with Cosmos S, ATCS 840, HAF 932, HAF 922(1) and Storm Sniper(1).
  • Adds extra cooling for graphics cards when installed on side panels.
(1) No LED On/Off function support
Cooler Master MegaFlow 200 - case fan
Case fan
Package Content
3-pin plug to 4-pin Molex adapter
Red
Fan Diameter
200 mm
Fan Height
30 mm
Fan Bearing
Sleeve bearing
Rotation Speed
700 rpm
Air Flow
110 cfm
Power Connector
3-pin plug, 4 pin Molex connector
Red LEDs
266 g
Case fan
Package Content
266 g
Red
Heatsink & Fan
Fan Diameter
200 mm
Fan Height
30 mm
Fan Bearing
Sleeve bearing
Rotation Speed
700 rpm
Air Flow
110 cfm
Power Connector
Red LEDs
Mounting Kit
Included
RoHS
Sound Emission
19 dBA
