The Hyper TX3 EVO cooling system is designed and optimized to provide the best user experience and cooling potential for a new generation of processors.Optimized for current and future generation sockets, the Hyper TX3 EVO sees improvement in its Direct Contact heat pipe performance, expanded socket support, and a higher quality 92mm wide-range PWM fan.
- Cooler Master Hyper TX3 EVO - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA1151 Socket, Socket AM4
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Long life sleeve bearing
- Rotation Speed
- 800-2200 rpm
- Air Flow
- 15.7-43.1 cfm
- Noise Level
- 17 - 30 dBA
- Power Connector
- 4-pin fan connector
- Heat-pipe Direct Touch (H.D.T.) Technology, Pulse-width modulation (PWM) support
- 7.9 cm x 9 cm x 13.6 cm
- 386 g
- Product Type
- Processor cooler
- 7.9 cm
- 9 cm
- 13.6 cm
- 386 g
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core i7 Extreme Edition , Core i7 , Core i5 , Core i3 , Core 2 Extreme , Core 2 Quad , Core 2 Duo , Pentium , Celeron , Phenom II , Phenom X3 , Phenom X4 , Athlon II , Athlon , Athlon X2 , Sempron
- Heatsink Material
- Aluminium
- Heatsink Dimensions
- 136 mm x 90 mm x 51 mm
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 800-2200 rpm
- Air Flow
- 15.7-43.1 cfm
- Air Pressure
- 0.35 - 2.63 mm
- Noise Level
- 17 - 30 dBA
- Power Connector
