The Hyper 412S CPU cooler is designed for optimum heat dissipation at low fan speeds. This is thanks to wider fin gaps and a precise heat pipe layout that directs each of their four heat pipes across CPU "hot zones". These heat pipes are arranged using Cooler Master's patented CDC technology, creating a virtual vapor chamber for maximum cooling potential. The 412S comes equipped with an ultra low speed silent mode fan adapter to virtually erase noise levels.
- Cooler Master Hyper 412S - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, Socket AM2+, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket
- Heatsink Material
- Aluminium and copper
- Fans Qty
- Dual
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Plain bearing
- Rotation Speed
- 1300 rpm
- Air Flow
- 36.4-52.6 cfm
- Power Connector
- 3-pin plug
- Heat pipe technology, Heat Direct Contact (H.D.C.) technology
- 13.2 cm x 9.9 cm x 16 cm
- 0.5 kg
- Product Type
- Processor cooler
- 13.2 cm
- 9.9 cm
- 16 cm
- 0.5 kg
Heatsink & Fan
- Compatible With
- Processor Compatibility
- Core i7 Extreme Edition , Core i7 , Core i5 , Core i3 , Core 2 Extreme , Core 2 Quad , Core 2 Duo , Pentium , Celeron , Phenom , Phenom II , Phenom X3 , Phenom X4 , Athlon II , Athlon X2 , Sempron
- Heatsink Material
- Fans Qty
- 2
- Fan Diameter
- 120 mm
- Fan Height
- 25 mm
- Fan Bearing
- Plain bearing
- Rotation Speed
- 1300 rpm
- Air Flow
- 36.4-52.6 cfm
- Air Pressure
- 1.4 mm
- Power Connector
- 3-pin plug
- Power Consumption
- 1.2 W
- Sound Emission
- 22.5 dBA
