CoolerMaster Hyper 212x 4 Heatpipe 1x 120 Pwm Fan Tower Cpu Cooler
Quicklinx: CC03WS00 Mfr#: RR-212X-17PK-R1
The Hyper 212X features a PWM-controlled fan and provides incredibly low noise level. Amazing CDC and X-Vent technologies, funnel-shaped aluminum fins and a series of perforated dimples create a CPU cooler that is optimized for great heat dissipation. The universal bracket design ensures easy and worry-free installation on every platform.
  • X-Vents design
    Positioned in a 45-degree angle and surrounding the heat pipe, each fin blade features X-shaped vents that create areas of high and low air pressure, resulting in several controlled vortices. These small and chaotic turbulences produce strong gusts that reduce overall airflow but improve airflow where it matters the most - next to the heat pipes.
  • V-shaped array
    Funnel-shaped aluminum fins and a series of perforated dimples guide the airflow towards the heat pipes. Specially designed X-Vents act similar to tiny airplane wings and prevent dead spots behind and between heat pipes. The combination of these technologies results in notably higher airflow over the heat pipes and the adjacent fin area, which reduces CPU temperatures.
  • CDC technology
    Several continuous direct-contact heat pipes create a gapless contact surface for amazing cooling efficiency.
  • Optimized fin design
    Aluminum fin array with tunnel effect creates micro vortices that boost the airflow and circulate it around the heat pipes.
Cooler Master Hyper 212X - processor cooler
Processor cooler
Compatibility
LGA1156 Socket, Socket AM2+, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, Socket FM2+, LGA2011-3 Socket, LGA1151 Socket
Heatsink Material
Aluminium
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
600-1700 rpm
Air Flow
24.9-82.9 cfm
Noise Level
9 - 27.2 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Heat pipe technology, Pulse-width modulation (PWM) support, 4 copper heatpipes (6 mm), Continuous Direct Contact (CDC) technology, X-Vent technology
7.9 cm x 12 cm x 15.8 cm
Europe
Processor cooler
7.9 cm
12 cm
15.8 cm
Europe
Heatsink & Fan
Compatible With
Heatsink Material
Aluminium
Heatsink Dimensions
158 mm x 116 mm x 51 mm
Fan Diameter
120 mm
Fan Height
25 mm
Fan Bearing
Rifle bearing
Rotation Speed
600-1700 rpm
Air Flow
24.9-82.9 cfm
Air Pressure
0.3-2.03 mm
Noise Level
9 - 27.2 dBA
Power Connector
4-pin fan connector
Rated Voltage
12 V
Rated Current
0.1 A
Power Consumption
1.2 W
MTBF
40,000 hour(s)
Limited warranty: - 2 years
