The Hyper 103 is an affordable mainstream heatsink that delivers great cooling performance. Air flow is optimized towards heatpipes thanks to a special fin design and exclusive X-Vent and Air-Guide technology. A 92 mm PWM fan has a wide speed range. This low profile tower heatsink is a great match for all modern small form factor systems.
3 direct contact heatpipes
The base is engineered to minimize CPU contact gaps. Also, stylish aluminum fins provide excellent heat dissipation. -
Funnel shaped aluminum fins and a series of perforated dimples guide airflow towards the heatpipes and, ultimately, reduces CPU temperatures. -
Exclusive X-Vent technology
Vents are placed at a 45 degrees angle around each heat pipe. They help guide airflow and create vorteces of air for better cooling. -
Wide-range 92 mm PWM fan
The Hyper 103's 92 mm PWM fan features a wide fan speed range and can be fine tuned for maximum airflow and cooling performance or silent operation. The low profile tower heatsink is a great match for small form factor systems.
- Cooler Master Hyper 103 RR-H103-22PB-R1 - processor cooler
- Product Type
- Processor cooler
- Compatibility
- LGA775 Socket, LGA1156 Socket, Socket AM2, LGA1366 Socket, Socket AM3, LGA1155 Socket, Socket AM3+, LGA2011 Socket, Socket FM1, Socket FM2, LGA1150 Socket, LGA1200 Socket
- Heatsink Material
- Aluminium
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Long life sleeve bearing
- Rotation Speed
- 800-2200 rpm
- Air Flow
- 15.7-43.1 cfm
- Noise Level
- 17 - 30 dBA
- Power Connector
- 4-pin fan connector
- Blue LEDs, heat pipe technology, Versatile Tool-free Multiplatform System (V.T.M.S.), X-Vent technology, Air-Guide technology
- 500 g
- 2-year warranty
- Product Type
- Processor cooler
- 500 g
Heatsink & Fan
- Compatible With
- Heatsink Material
- Aluminium
- Heatsink Dimensions
- 138.5 mm x 96 mm x 61 mm
- Fan Diameter
- 92 mm
- Fan Height
- 25 mm
- Fan Bearing
- Rotation Speed
- 800-2200 rpm
- Air Flow
- 15.7-43.1 cfm
- Air Pressure
- 0.35 - 2.63 mm
- Noise Level
- 17 - 30 dBA
- Power Connector
- Start Voltage
- 12 V
- Rated Current
- 0.15 A
- Limited warranty: - 2 years
