The Elite 430 Black was designed with all-black interior coating with the main purpose in mind to give enough space for large graphics cards, no matter what your brand preference is. The Elite 430 Black also features plenty of cooling options and a well ventilated front mesh design to keep even the hottest system cool.
- Cooler Master Elite 430 - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black
- Image Colour Disclaimer
- The displayed product image may be a different colour
- I/O Connectors
- 2 x USB 2.0 , 1 x microphone , 1 x audio line-out/headphones
- Supported Motherboards
- ATX, microATX
- System Cabinet Features
- Top panel dust filter, meshed front panel, floor dust filter, water cooling holes
- Power Device
- No power supply (ATX / PS/2)
- 19 cm x 49 cm x 42.4 cm
- 4.7 kg
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- ATX, microATX
- Internal Bays Qty
- 5
- Front Accessible Bays Qty
- 5
- Black
- Cooling System
- Top: 120 mm fan mount x 2 , Front: 120 mm fan x 1 / red LED, 1 x 140 mm fan supported , Rear: 80/90/120 mm fan mount x 1 , Side: 120 mm fan mount x 1 , Bottom: 80/90/120 mm fan mount x 1
- CPU Cooler Max Height
- 163 mm
- Video Card Max Length
- 315 mm
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" , 2 (total) / 2 (free) x front accessible - 3.5" , 5 (total) / 5 (free) x internal - 3.5"
- Expansion Slots
- 7
- 2 x USB 2.0 , 1 x microphone - mini-jack , 1 x audio line-out/headphones - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX / PS/2
- Max Supported Qty
- 1
- 19 cm
- 49 cm
- 42.4 cm
- 4.7 kg
