The Elite 110 is a mini cube compact case with support for full size standard desktop components. Other than the conventional mini-ITX case, the Elite 110 supports ample storage up to 3 HDDs / 4 SSDs and you can even install a radiator in the front for extreme cooling. It can accommodate the standard full size ATX PSU and the short dual slots graphic cards.
- Cooler Master Elite 110 - USFF - mini ITX
- Product Type
- System cabinet
- Form Factor
- Ultra small form factor
- Midnight black
- I/O Connectors
- 2 x USB 3.0 , 1 x microphone , 1 x audio line-out
- Supported Motherboards
- Mini-ITX
- System Cabinet Features
- Meshed front panel, blue LED
- Power Device
- (ATX / PS/2)
- 26 cm x 28 cm x 20.8 cm
- 2.65 kg
- Form Factor
- Max Mainboard Size
- Mini ITX
- Mini-ITX
- Internal Bays Qty
- 3
- Midnight black
- Cooling System
- Front: 120 mm fan x 1 / 1 x 140 mm fan supported , Side: 80 x 80 x 25 mm fan mount x 1
- CPU Cooler Max Height
- 76 mm
- Video Card Max Length
- 210 mm
- Expansion Bays
- 3 (total) / 3 (free) x internal - 3.5" x 1/3H
- Expansion Slots
- 2
- 2 x USB 3.0 , 1 x microphone - mini-jack , 1 x audio line-out - mini-jack
- Specification Compliance
- ATX / PS/2
- Max Supported Qty
- 1
- 26 cm
- 28 cm
- 20.8 cm
- 2.65 kg
