CoolerMaster Cosmos 2 - USB 3.0  XL-ATX Case
Quicklinx: 8K8SWS00 Mfr#: RC-1200-KKN1
Inspired by luxurious supercars, the exterior of the Cosmos II melds aluminum, steel, and mesh into an elegant artistic piece. It maintains its trademark Cosmos profile and outlook with its reinforced aluminum rails while being further refined for today's advancements in air/water cooling, peripheral support, and styling. Large swinging aluminum side panels and sliding doors lend to its stylish and smooth movements to access ports, drives, and system hardware. With the Cosmos II, build as you wish as the options are endless.
Cooler Master Cosmos II - tower - extended ATX
System cabinet
Tower
Midnight black
I/O Connectors
4 x USB 2.0 , 2 x USB 3.0 , 1 x eSATA , 1 x microphone , 1 x headphones
Supported Motherboards
ATX, microATX, Extended ATX, SSI CEB, SSI EEB, XL-ATX
System Cabinet Features
Meshed front panel
No power supply (EPS12V/ PS/2)
34.4 cm x 70.4 cm x 66.4 cm
22 kg
Tower
Max Mainboard Size
Extended ATX
Internal Bays Qty
11
Front Accessible Bays Qty
5
Product Material
Aluminium
Midnight black
Cooling System
Front: 200 mm fan x 1 / 700 rpm / 19 dBA / 1 x 120/140 mm fan supported , Top: 120 mm fan x 1 / 1200 rpm / 17 dBA , Rear: 140 mm fan x 1 / 1200 rpm / 19 dBA , Side: 120 mm fan mount x 2 , Top: 120 mm fan mount x 3 / 1 x 200 mm fan or 2 x 140 mm fan supported , Internal: 120 mm fan mount x 1 , Internal: 120 mm fan x 2 / 1200 rpm / 17 dBA
Meshed front panel
Expansion Bays
3 (total) / 3 (free) x front accessible - 5.25" x 1/2H , 2 (total) / 2 (free) x front accessible - 3.5" x 1/3H , 11 (total) / 11 (free) x internal - 3.5" x 1/3H
Expansion Slots
11 x Expansion Slot
4 x USB 2.0 , 2 x USB 3.0 , 1 x eSATA , 1 x microphone - mini-jack , 1 x headphones - mini-jack
No power supply
Specification Compliance
EPS12V/ PS/2
Max Supported Qty
1
34.4 cm
70.4 cm
66.4 cm
22 kg
