Built to be amongst the most agile full-towers, Stryker includes an ultra-strong travel-ready carrying handle. CM Storm Stryker has a stylish glossy finish on the case and included fans, windowed side panel, full dust filter coverage, a fan controller, an external SSD drive hot-swap dock and two uniquely designed modular hard drive cages. These features give CM Storm Stryker the ability to adapt to workstation or water-cooled gaming configurations easily.
- Cooler Master CM Storm Stryker - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Black & white
- Built-in Devices
- External SATA X-Dock
- I/O Connectors
- 2 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-out , 1 x microphone
- Supported Motherboards
- ATX, microATX, XL-ATX
- System Cabinet Features
- Carrying handle, rotational drive cage, top panel dust filter, removable dust filter, fan speed controller, meshed front panel, floor dust filter, Storm Guard
- Power Device
- No power supply (ATX12V / EPS12V / PS/2)
- 25 cm x 60.5 cm x 57.85 cm
- 13.7 kg
- 2-year warranty
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- Internal Bays Qty
- 8
- Front Accessible Bays Qty
- 9
- Hot-Swap Bays Qty
- 1
- Built-in Devices
- Black & white
- Cooling System
- Front: 120 mm fan x 2 / 1200 rpm / 17 dBA / white LED , Top: 200 mm fan x 1 / 1000 rpm / 23 dBA / 2 x 120/140 mm fan supported , Rear: 140 mm fan x 1 / 1200 rpm / 19 dBA , Bottom: 120 mm fan mount x 2
- Expansion Bays
- 9 (total) / 9 (free) x front accessible - 5.25" x 1/2H , 8 (total) / 8 (free) x internal - 3.5" x 1/3H , 13 (total) / 13 (free) x internal - 2.5"
- Expansion Slots
- 10 x Expansion Slot
- 2 x USB 2.0 , 2 x USB 3.0 , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack
- Power Device
- No power supply
- Specification Compliance
- ATX12V / EPS12V / PS/2
- Max Supported Qty
- 1
- 25 cm
- 60.5 cm
- 57.85 cm
- 13.7 kg
- Limited warranty - 2 years
