Cooler Master developed the V-series to re-ascertain its position as the worlds top power supply brand. It features outstanding efficiency, especially at typical low idle loads, excellent hold up times, voltage stability and ripple suppression. It only uses highest grade Japanese capacitors, most of them solid capacitors, as well as a massive high quality 42mm transformer.
And thanks to high quality FDB fans V-series PSUs are extremely cool and quiet. The V-series uses a fully modular cable system with beautiful all black, extra slim flat-ribbon cables. This makes cable management a breeze and results in nice looking clean builds with the best possible airflow.
- Cooler Master V Series V700 - power supply - 700 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31
- 80 PLUS Certification
- 80 PLUS Gold
- Localisation
- United Kingdom
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 700 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 58 A , -12V - 0.5 A , +5VSB - 2.5 A
- Input Connectors
- 1
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 9 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- 15 cm x 17 cm x 8.6 cm
- 5-year warranty
- ATX12V 2.31
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 700 Watt
- Output Current
- 80 PLUS Gold
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Over voltage protection, overpower protection, undervoltage protection, short-circuit protection, thermal protection, fully modular
- TUV, C-Tick, BSMI, GOST, CCC, FCC, KCC
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 15 cm
- 17 cm
- 8.6 cm
