The exterior retains the curved metal mesh look the series is known for. The interior has been completely updated - the HDD/SSD combo cage can be switched between 3.5-inch or 2.5-inch drives by adjustable trays without any screw. There's enough room for a 240 mm liquid cooling radiator at the top or front, 120 mm in the rear and supports up to 9 fans, including 3 large 200 mm fans for extreme airflow. And cleaning is hassle free thanks to the multiple dust filters at the bottom, top, and front.
- Cooler Master CM 690 III - tower - ATX
- Product Type
- System cabinet
- Form Factor
- Tower
- Windowed Side Panel
- Midnight black
- I/O Connectors
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-out/headphones , 1 x microphone
- Supported Motherboards
- ATX, microATX
- System Cabinet Features
- Top panel dust filter, removable dust filter, meshed front panel, front dust filter, liquid cooling holes, rear dust filter, meshed top, cable management system, supports 240 mm radiator in front panel, supports 240 mm radiator in top, supports 120 mm radiator in rear
- Power Device
- No power supply (ATX / PS/2)
- 23 cm x 50.7 cm x 50.2 cm
- 8.7 kg
- Form Factor
- Tower
- Max Mainboard Size
- ATX
- ATX, microATX
- Internal Bays Qty
- 10
- Front Accessible Bays Qty
- 3
- Midnight black
- Cooling System
- Top: 120/140 mm fan mount x 1 / 1 x 200 mm fan supported , Front: 200 mm fan x 1 / 2 x 120/140 mm or 1 x 180 mm fan supported , Rear: 120 mm fan x 1 , Bottom: 120 mm fan mount x 1 , Internal: 120 mm fan mount x 1
- CPU Cooler Max Height
- 171 mm
- Video Card Max Length
- 423 mm
- Expansion Bays
- 3 (total) / 3 (free) x front accessible - 5.25" , 7 (total) / 7 (free) x internal - 2.5" / 3.5" shared , 3 (total) / 3 (free) x internal - 2.5"
- Expansion Slots
- 8
- 2 x USB 3.0 , 2 x USB 2.0 , 1 x audio line-out/headphones - mini-jack , 1 x microphone - mini-jack
- Included Accessories
- 3.5" to 2.5" bay adapter
- Power Device
- No power supply
- Specification Compliance
- ATX / PS/2
- 23 cm
- 50.7 cm
- 50.2 cm
- 8.7 kg
