The reliable, efficient and premium line of B power supplies is ideal for mainstream and basic computing systems. Built with quality components and dual +12 V outputs, the B series can handle demands of high power requirements. In addition to the stable and clean power, the highly developed features incorporated include worry-free protection system and Green Power design to meet ENERGY STAR, Blue Angel, and ErP 2010 requirements.
- Cooler Master B500 - power supply - 500 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.3
- Input Voltage
- AC 180-264 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- +3.3V - 22 A , +5V - 19 A , +12V1 - 24 A , +12V2 - 21 A , -12V - 0.3 A , +5VSB - 2.5 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 1 x 8 pin PCI Express power with detachable 2 pin section , 3 x 4 PIN internal power , 6 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Cooling System
- 120 mm fan
- 15 cm x 14 cm x 8.6 cm
- 3-year warranty
- ATX12V 2.3
- PSU Form Factor
- ATX
- Input Voltage
- AC 180-264 V
- Input Voltage Range
- AC 200 - 240 V
- Frequency Required
- 47 - 63 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 500 Watt
- Output Current
- Efficiency
- 85%+
- MTBF
- 100,000 hours
- Cooling System
- 120 mm fan
- Over current protection, over voltage protection, overpower protection, dual 12V rails, short-circuit protection
- TUV, C-Tick, GOST
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 15 cm
- 14 cm
- 8.6 cm
