Cooler Master developed the V-series to re-ascertain its position as the worlds top power supply brand. It features outstanding efficiency, especially at typical low idle loads, excellent hold up times, voltage stability and ripple suppression. It only uses highest grade Japanese capacitors, most of them solid capacitors, as well as a massive high quality 42mm transformer.
And thanks to high quality FDB fans V-series PSUs are extremely cool and quiet. The V-series uses a fully modular cable system with beautiful all black, extra slim flat-ribbon cables. This makes cable management a breeze and results in nice looking clean builds with the best possible airflow.
Fully modular cable system
Only use the cables you need, no unnecessary cable mess! Thanks to Cooler Master’s modular flat-ribbon design, routing and hiding cables behind the mainboard tray or HDD cage is a breeze Building a clean and tidy system with excellent airflow has never been this easy and convenient. -
Ultra silent long life - 135mm FDB Fan
Instead of a conventional 120mm fan. Cooler Master’s V series uses a larger 135mm fan. which allows it to spin slower while moving the same amount of air as a 120mm fan. The larger size, the FDB bearing and the fine-tuned fan speed profile, make the V-series one of the quietest PSUs on the market. -
The most important voltage
The 12V rail is the most important part of a modem power supply. Both the CPU and graphics cards, the two most important and power hungry components in any computer, are powered by the 12V line. Voltage fluctuations can cause anything from high pitch noises, to lower CPU and VGA overclocks, system instability or even damage components. -
FDB Advantages
Thanks to an elaborate design with microscopic tolerances and a detailed channel design, the bearing core and inner case are constantly separated by a thin film of oil. and the two metal parts never actually touch! The channels on the bearing core act as a pump, constantly looping it back to the center, giving it no chance to leak. This results in extremely quiet operation and an extremely long life.
- Cooler Master V Series V1000 - power supply - 1000 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.31
- 80 PLUS Certification
- 80 PLUS Gold
- Localisation
- United Kingdom
- Input Voltage
- AC 115/230 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1000 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V - 83 A , -12V - 0.5 A , +5VSB - 2.5 A
- Input Connectors
- 1
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 2 x power 8 pin +12V with detachable 4 pin section , 8 x 8 pin PCI Express power with detachable 2 pin section , 4 x 4 PIN internal power , 9 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- 15 cm x 17 cm x 8.6 cm
- 5-year warranty
- ATX12V 2.31
- PSU Form Factor
- ATX
- Localisation
- United Kingdom
- Input Voltage
- AC 115/230 V
- Input Voltage Range
- AC 90 - 264 V
- Frequency Required
- 47 - 63 Hz
- Input Connectors
- 1
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 1000 Watt
- Output Current
- Efficiency
- 93%
- 80 PLUS Gold
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Overheat protection, over voltage protection, overpower protection, undervoltage protection, short-circuit protection, fully modular
- TUV, C-Tick, BSMI, GOST, CCC, FCC, KCC
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 15 cm
- 17 cm
- 8.6 cm
