The Cisco WIP310 Wireless-G IP Phone enables high-quality voice over IP (VoIP) service through a Wireless-G network.
The Cisco WIP310 operates in the 2.4-GHz band and supports 802.11b/g and the VoIP Session Initiation Protocol (SIP). The large, full-color high-resolution display features an intuitive user interface that enables users to easily and quickly configure the handset with network access using Wi-Fi Protected Setup (WPS).
WPS is a fast, highly secure way of connecting the Cisco WIP310 IP phone with any standards-based Wireless-G broadband router. Just press the WPS button and your connection will automatically be configured and secured with a custom service set identifier (SSID) using powerful Wi-Fi Protected Access (WPA) encryption. Within seconds you have successfully set up a highly secure connection.
The Cisco WIP310 uses the same trusted and proven provisioning capabilities presently being used to deploy other popular Cisco voice products for small and medium-sized businesses on a massive scale. Customers purchasing VoIP service from a service provider and using the Cisco WIP310 can be quickly provisioned over a Wi-Fi connection, receiving their configuration profile securely right to the handset via a Trivial File Transfer Protocol (TFTP), HTTP, or HTTPS download.
The included telephone base accentuates the modern design of the handset and provides hands-free convenience when using the built-in speakerphone. The Cisco WIP310 supports many features such as caller ID, call forwarding, call transfer, and three-way conferencing and can store 200 records in its phone book.
Benefit with low-cost VoIP service and access to any Wireless-G network using the WIP310 Wireless-G IP Phone from Cisco.
Efficient power usage
Equipped with a rechargeable 860 mAh lithium-ion battery, this device ensures up to 180 minutes of talk time and up to 40 hours of standby time, minimizing the need for frequent recharging. -
Crystal clear display
Features a 1.8-inch LCD display with backlight, offering a resolution of 128 x 160 pixels. This compact yet clear screen displays information in vivid color, supporting up to 65000 colors for enhanced readability. -
Enhanced connectivity
Supports VoIP with SIP and SIP v2 protocols, facilitating efficient and reliable communication over the Internet. With options for DHCP and static IP address assignment, it integrates seamlessly into a variety of network environments. -
Robust security features
Provides multiple layers of security, including 128-bit WEP, 64-bit WEP, WPA, and WPA2, to protect your communications from unauthorized access and ensure privacy. -
Comprehensive call management
Offers a suite of call services including call forwarding, call hold, call transfer, call waiting, caller ID, and voice mail capability. Combined with a built-in clock, polyphonic ringer, and speakerphone, it enhances the user experience by streamlining call handling.
- Cisco Small Business WIP310 - wireless VoIP phone - 3-way call capability
- Product Type
- Wireless VoIP phone
- Total Number of Wireless Handsets
- 1
- Cordless Phone Standard
- IEEE 802.11g (Wi-Fi)
- VoIP Protocols
- SIP, SIP v2
- Voice Codecs
- G.729ab, G.711u, G.711a, G.726
- Speakerphone
- Caller ID
- Voice Mail Capability
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
- Display
- LCD display - colour - Yes
- Product Type
- 1
Phone Features
- Call Services
- Max Handset Operating Distance
- 100 m
- Max Handset Operating Distance (Outdoor)
- 300 m
- Dialer Type
- Keypad
- Dialer Location
- Handset
- Conference Call Capability
- 3-way
- Speakerphone
- Short Messaging Service (SMS)
- Menu Operation
- Function Buttons
- Speakerphone button, directory button
- Volume Control
- Ringer Control
- Polyphonic Ringer
- Lighted Keypad
- Firmware Upgradable
- Additional Functions
- Built-in clock
- Additional Features
- Key lock, built-in web server
IP Telephony
- VoIP
- VoIP Protocols
- SIP, SIP v2
- Voice Codecs
- IP Address Assignment
- DHCP, static
- Security
- 128-bit WEP, 64-bit WEP, WPA, WPA2
- Network Protocols
- IP, TCP, TFTP, UDP, HTTP
- Voice Features
- Echo cancellation (ECN)
- Network Features
- Network Address Translation (NAT)
Phone Memory
- Phone Directory Capacity
- 200 names & numbers
Display
- Display Location
- Handset
- Diagonal Size
- 1.8"
- Display Resolution
- 128 x 160 pixels
- Colour Depth
- 16-bit (65000 colours)
- Backlit
- Aerial
- Internal
- Connections
- DC power input / mini-USB Type B , Headset jack / sub-mini-phone 2.5mm
- Cables Included
- USB cable
- Included Accessories
- Power adapter, phone charging stand
- FCC
- Phone charging stand + power adaptor - external
- Capacity
- 860 mAh
- Technology
- Rechargeable - Lithium Ion
- Talk Time
- Up to 180 min
- Standby Time
- Up to 40 h
Dimensions & Weight (Handset)
- 4.4 cm
- 2.5 cm
- 14.9 cm
- 110 g
