Cisco UC Phone 8851
Cisco UC Phone 8851
Quicklinx: B75GWS00 Mfr#: CP-8851-K9=
Type: VoIP phone
Handsets Included: [N/A]
Answer Machine: [N/A]
Nuisance Call Blocker: No
Mounting: Table mount, Wall-mountable
Hurry, only 3 left in stock!
£384.85 ex VAT
£461.82 inc VAT
The Cisco IP Phone 8851 is a business-class collaboration endpoint that combines high-fidelity, reliable, secure, and scalable voice communications with Cisco Intelligent Proximity for telephony integration for personal mobile devices to support midsize to large enterprise businesses.
With the Cisco IP Phone 8851, you can increase personal productivity through an engaging user experience that is both powerful and easy-to-use. The IP Phone 8851 combines an attractive ergonomic design with wideband audio for crystal clear voice communications, "always-on" reliability, encrypted voice communications to enhance security, and access to a comprehensive suite of unified communication features from Cisco communication servers.
In addition, Cisco Intelligent Proximity brings the worlds of desk and mobile together for you when you are using your mobile device at the desk for your work. You can move the audio path over to the Cisco IP Phone 8851 during active mobile calls to take advantage of its superior audio acoustics. An example would be to share a conversation with a colleague who you want to listen in. This capability gives you greater flexibility and a superior user experience when at your desk.
The IP Phone 8851 also comes standard with a USB port so you can charge your smartphone when at your desk, and stay connected when away from your desk.
The Cisco IP Phone 8851 offers five programmable line keys. You can configure keys to support either multiple directory numbers or calling features such as speed dial. You can also boost productivity by handling multiple calls for each directory number using the multicall-per-line feature. Fixed-function keys give you one-touch access to applications, messaging, directory, as well as often-used calling features such as hold/resume, transfer, and conference. A five-way navigation cluster helps you transition through menus more easily. Backlit acoustic keys provide flexibility for audio path selection and switching.
  • LARGE DISPLAY
    5-inch high-resolution widescreen WVGA colour display with localised language support to meet the needs of global users
  • FIXED FUNCTION KEYS
    One-touch access to service, messaging, directory, hold/resume, transfer and conference features
  • FULLY PROGRAMMABLE
    Set up line keys to support either lines, such as directory numbers, or call features like speed dialling
  • OPTIMAL PERFORMANCE
    Class 4 PoE with a built-in Ethernet Gigabit switch for your PC connection
  • PEACE OF MIND
    1-year limited hardware warranty
Cisco IP Phone 8851 - VoIP phone
VoIP phone
Compatible Platforms
Cisco Business Edition 6000
Main Features
Multiple VoIP protocol support, integrated Ethernet switch
VoIP Protocols
SIP, RTCP, RTP, SRTP, SDP
Voice Codecs
G.722, G.729a, G.711u, G.711a, iLBC, iSAC
Lines Supported
5 lines
Intercom
Speakerphone
Yes (digital duplex)
Call Services
Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold, Message Waiting Capability
Display
LCD display - colour - Yes
Network Ports Qty
2 x Ethernet 10Base-T/100Base-TX/1000Base-T
Compatible Software
Cisco Unified Communications Manager 8.5.1 or later, Cisco Hosted Collaboration Solution, Cisco Unified Communications Manager Express 10.0 or later
1-year warranty
VoIP phone
Body Material
ABS plastic
Phone Features
Wireless Interface Provided
Bluetooth
Bluetooth Profiles
Hands-Free Profile (HFP), Phonebook Access Profile (PBAP)
Call Services
Key Expansion Module Max Qty
2
Dialer Type
Keypad
Dialer Location
Base
Conference Call Capability
Intercom
Speakerphone
Menu Operation
Programmable Buttons Qty
5
Indicators
Voice message waiting indicator, speakerphone indicator, headset
Firmware Upgradable
Additional Functions
Call timer, Intercom
Additional Features
Music on hold, BLF status lamps, compatible with Bluetooth headsets
IP Telephony
Main Features
VoIP
VoIP Protocols
Voice Codecs
Lines Supported
5 lines
Quality of Service
IEEE 802.1Q (VLAN), IEEE 802.1p
Security
IEEE 802.1X, TLS
Power Over Ethernet (PoE) Support
Network Protocols
IP, TFTP, UDP, Cisco Discovery Protocol (CDP), HTTP, DNS, HTTPS, SRTP, Link Layer Discovery Protocol - Media Endpoint Discovery (LLDP-MED), RTCP, RTP
Network Ports Qty
Compatible Software
Network Features
Class 3 PoE
Display
Display Location
Base
Diagonal Size
5"
Display Resolution
800 x 480 pixels
Colour Depth
24-bit (16.7 million colours)
Backlit
Display Languages
Danish, Hebrew, Hungarian, Czech, Croatian, Slovenian, Thai, Slovak, Brazilian Portuguese, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Bulgarian, Latvian, Lithuanian, Estonian, Serbian, Romanian, Catalan, Japanese, Chinese, Korean
Headset jack / RJ-9 , Electronic hook switch (EHS) , USB
Hearing Aid Compatible
Placing / Mounting
Wall-mountable, table mount
CISPR 22 Class B, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, EN55022 Class B, ICES-003 Class B, AS/ACIF S004, RSS-210, RSS-102, FCC Part 68, ADA, CS-03, UL 60950-1 Second Edition, EN 60601-1-2, FCC CFR47 Part 15 B, GB 4943, AS/NZS 60950, HAC (Hearing Aid Compatible), CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, EN 300 328, EN 301 489-1, EN 301 489-17
Dimensions & Weight (Base)
25.734 cm
4 cm
22.91 cm
1.19 kg
Limited warranty - replacement - 1 year
B75G Cisco Wall Mount Kit For IP Phone 8841, 8851, 8861 In Stock £46.21
Type: VoIP phone
Mounting: Wall-mountable
Big Button: No
Brand: Cisco
