Cisco Wide Area Application Engine 512, 1GB MEM 1x250HDD
Quicklinx: 68ZDWS00 Mfr#: WAE-512-K9
The Cisco WAE-512 Wide Area Application Engine is designed for small to medium size branch edge deployments and provides customers with a low-cost, high-performance platform to host Cisco's WAN optimization and application acceleration solutions. The Cisco WAE-512 is designed to easily integrate into existing branch network infrastructure, both logically and physically and is provided in a single rack-unit form factor. The Cisco WAE-512 includes 1GB of RAM in the base chassis with options to upgrade to 2GB of RAM for improved performance and scaling. When deployed with Cisco WAAS, two front-loadable Serial Advanced Technology Attachment (SATA) disk drive bays can be configured with up to two 250GB hard disk drives using Redundant Array of Independent Disks (RAID; simple swap) to facilitate high disk availability.
Cisco Wide Area Application Engine 512 - application accelerator
Application accelerator
Rack-mountable - 1U
RAM
1 GB (installed) / 2 GB (max)
Flash Memory
128 MB
44 cm x 55.9 cm x 4.3 cm
12.7 kg
Height (Rack Units)
1U
44 cm
55.9 cm
4.3 cm
12.7 kg
Processor / Memory / Storage
RAM
1 GB (2 GB max) DDR2 SDRAM DIMM 240-pin
Flash Memory
128 MB
Rack-mountable
Wired
Expansion Slots
2 (total) / 1 (free) x DIMM 240-pin
2 x 1000Base-T - RJ-45
FCC Class A certified, EN 60950, UL 1950, VCCI Class A ITE, IEC 60950, EN55024, CSA 22.2 No. 950, EN55022 Class A, EN50082-1, ICES-003 Class A, AS/NZS 3548, FCC CFR47 Part 15
Internal power supply
Power Provided
350 Watt
10 °C
35 °C
8 - 80%
