Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
Enhanced connectivity
The Cisco StackWise Plus model includes a stacking cable that significantly improves the connectivity between network switches, allowing for a more integrated and efficient network infrastructure -
PC compatibility
Designed with PC compatibility in mind, this product ensures seamless integration into existing network setups, making it a versatile choice for a wide range of applications
- Cisco StackWise Plus - stacking cable - 50 cm
- Stacking cable
- Length
- 50 cm
- Designed For
- Catalyst 2960, 2960-24, 2960-48, 2960G-24, 2960G-48, 2960S-24, 2960S-48, Switch Module 3110
- Network Cable Type
- Stacking cable
- Length
- 50 cm
- Designed For
- Cisco Catalyst 2960-24LC-S, 2960-24LT-L, 2960-24PC-L, 2960-24PC-S, 2960-24-S, 2960-24TC, 2960-24TC-L, 2960-24TC-S, 2960-24TT, 2960-48PST-L, 2960-48PST-S, 2960-48T, 2960-48TC, 2960-48TC-L, 2960-48TC-S, 2960-48TT, 2960-48TT-L, 2960-48TT-S, 2960-8TC, 2960-8TC-S, 2960G-24TC, 2960G-48TC, 2960G-8TC, 2960PD-8TT-L, 2960S-24PD-L, 2960S-24PS-L, 2960S-24TD-L, 2960S-24TS-L, 2960S-24TS-S, 2960S-48FPD-L, 2960S-48FPS-L, 2960S-48LPD-L, 2960S-48LPS-L, 2960S-48TD-L, 2960S-48TS-L, 2960S-48TS-S, Switch Module 3110G for IBM BladeCenter, Switch Module 3110X for IBM BladeCenter
