Efficient power management
The Cisco StackPower technology offers an innovative power sharing and redundancy model, ensuring that your network infrastructure remains operational even in the event of a power supply failure. This feature is crucial for maintaining system reliability and uptime, making it an essential asset for any business reliant on continuous network availability. -
Seamless integration
Designed specifically for compatibility with PC systems, this power cable ensures a hassle-free setup process. Its precise engineering ensures a perfect fit with compatible devices, facilitating a smooth and efficient power supply connection without the need for additional adapters or modifications.
- Cisco StackPower - power cable - 30 cm
- Power cable
- Length
- 30 cm
- Designed For
- Catalyst 3750X-12S-E, 3750X-12S-S, 3750X-24P-L, 3750X-24P-S, 3750X-24S-E, 3750X-24S-S, 3750X-24T-L, 3750X-24T-S, 3750X-48PF-L, 3750X-48PF-S, 3750X-48P-L, 3750X-48P-S, 3750X-48T-L, 3750X-48T-S
- Power cable
- Length
- 30 cm
- Designed For
- Cisco Catalyst 3750X-12S-E, 3750X-12S-S, 3750X-24P-L, 3750X-24P-S, 3750X-24S-E, 3750X-24S-S, 3750X-24T-L, 3750X-24T-S, 3750X-48PF-L, 3750X-48PF-S, 3750X-48P-L, 3750X-48P-S, 3750X-48T-L, 3750X-48T-S
