Product
Cisco Small Business SG300-28MP 28 ports - Managed - Desktop/Rack-Mountable Switch
Quicklinx: B0P1WS00 Mfr#: SG300-28MP-K9-UK
Cisco 300 series switch delivers the ideal combination of price, performance, and capabilities in a solution designed specifically for small businesses. This broad portfolio of affordable managed switches provides a powerful foundation to support your business network.
  • High performance and reliability
    Get the high availability and performance you need to support vital business applications while reducing downtime.
  • Advanced features
    Control network traffic with advanced features such as quality of service (QoS), Layer 3 static routing, and IPv6 support.
  • Easy setup and management
    Intuitive browser-based tools, mass deployment capabilities, and consistent features across it simplify setup and configuration.
  • An eco-friendly solution
    Switch optimizes power usage for energy efficiency without compromising performance.
Cisco Small Business SG300-28MP - switch - 28 ports - Managed - rack-mountable
Switch - 28 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
24 x 10/100/1000 (PoE+) + 2 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
375 W
Performance
Switching capacity: 56 Gbps , Forwarding performance (64-byte packet size): 41.67 Mpps
ACL rules: up to 512
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IPv4 routing
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH, CLI
Layer 3 switching, Layer 2 switching, DHCP support, BOOTP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, firmware upgradable, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Jumbo Frames support, MLD snooping
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at
44 cm x 35 cm x 4.45 cm
5.26 kg
Chinese (simplified), English, German, French, Italian, Spanish, Japanese / United Kingdom
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
375 W
Performance
8K entries
Jumbo Frame Support
10KB
Routing Protocol
Static IPv4 routing
Encryption Algorithm
SSL
Authentication Method
Secure Shell (SSH), RADIUS, TACACS+
RAM
128 MB
Flash Memory
16 MB
Status Indicators
Port transmission speed, system, link/activity
24 x 1000Base-T RJ-45 PoE+ , 4 x 1000Base-T RJ-45 , 1 x console DB-9 management , 2 x 1000Base-X SFP
Internal power supply
1 x serial cable
Rack Mounting Kit
Included
MTBF
138,677 hours
UL 60950, FCC Part 15 A, CSA 22.2
44 cm
35 cm
4.45 cm
5.26 kg
Limited warranty - replacement - lifetime - response time: next business day , Technical support - web support - 1 year , Technical support - phone consulting - 1 year
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
B0P1 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.19
B0P1 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.62
B0P1 C2G 2m Cat6a Shielded Patch - Blue In Stock £7.24
