Demand for managed services is expected to grow dramatically, with small businesses - those with fewer than 100 employees - expected to make up more than half of this market opportunity. These companies may have complex IT needs but generally don't have the technical staff or expertise needed to keep up. They look to service providers for a flexible infrastructure and simplified management, along with better quality and reliability than they can achieve in-house. To meet this opportunity, service providers are transforming their networks, using services-ready platforms to deliver an array of profitable IP-based communications services.
Cisco SRP 500 series Services Ready Platform is a flexible, cost-effective fixed-configuration customer premises equipment (CPE) with embedded intelligence to enable service providers to create, provision, and deploy premium revenue-generating services to small businesses on an as-needed basis. This platform will help enable service providers to deliver differentiated, converged service offers that increase bandwidth usage and average revenue per user while reducing customer churn.
Embedded intelligence
Embedded intelligence supports concurrent, premium revenue-generating services such as voice, data, security, and applications. Service providers can easily create and provision a variety of service offerings, adding or removing them remotely as their customers' needs change. -
Industry-leading SIP stack
Industry-leading SIP stack delivers an advanced implementation of standard voice coding algorithms for clear, high-quality voice under diverse network conditions, along with support for common telephony features such as voice mail, fax, and interactive voice response systems. -
Interoperability
Interoperability with industry-leading soft switches and voice gateways enable service providers to deploy highly efficient, scalable end-to-end multi-service networks. -
Standards-based provisioning
Standards-based provisioning, with support for TR-069, TR-104, and XML, that reduces operating expenses by enabling zero touch deployments, eliminating the need for highly skilled technicians and costly truck rolls to deploy new services. -
Compact design
Compact design integrates voice, data, switching, wireless, security, and application support in a desktop device that is ideal for simple, space-saving small business deployments.
- Cisco Small Business SRP541W - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Capacity
- Virtual interfaces (VLANs): 10 , IPSec VPN tunnels: 5
- TCP/IP, PPTP, UDP/IP, L2TP, ICMP/IP
- Routing Protocol
- RIP-1, RIP-2, IGMPv2, IGMP, static IP routing, GRE, policy-based routing (PBR)
- Remote Management Protocol
- SNMP 1, SNMP 2, SNMP 3, HTTP, HTTPS
- VoIP Functionality
- VoIP phone adapter
- VoIP Protocols
- SIP v2
- Telephony Interfaces
- 1 line (FXO), 4 phone (FXS)
- Firewall protection, DHCP support, NAT support, ARP support, VLAN support, auto-uplink (auto MDI/MDI-X), Syslog support, traffic shaping, Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, DiffServ support, MAC address filtering, Broadcast Storm Control, VPN passthrough, High Availability, URL filtering, firmware upgradable, Low-latency queuing (LLQ), Weighted Fair Queuing (WFQ), Spanning Tree Protocol (STP) support, IPSec Virtual Private Network (VPN), Wi-Fi Multimedia (WMM) support, event log, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, Multiple SSID support, DNS proxy, port forwarding, IPv4 support
- IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3ad (LACP), IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
- Power
- AC 120/230 V
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Capacity
- Routing Protocol
- Encryption Algorithm
- DES, Triple DES, 128-bit WEP, 64-bit WEP, TKIP, WPA, WPA2
- Authentication Method
- RADIUS, Radio Service Set ID (SSID)
- IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.3ad (LACP), IEEE 802.11g, IEEE 802.11i, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, ETSI, CISPR 24, EN 61000-3-2, ICES-003, EN 61000-3-3, EN55024, CISPR 22, EN50082-1, AS/NZS 60950-1, RSS-210, EN 61000-4-4, EN 61000-4-2, EN 61000-4-3, EN 61000-4-6, FCC Part 15, CS-03, EN 61000-4-5, EN 61000-6-2, EN 61000-4-11, FCC CFR47 Part 15, EN 61000-4-8, UL 60950-1, IEC 60950-1, EN 60950-1, EN 300 386
- RAM
- 64 MB
- Flash Memory
- 32 MB
- Status Indicators
- Power, phone, WLAN, WAN, LAN
IP Telephony
- VoIP Protocols
- SIP v2
- Voice Codecs
- G.711, G.723.1, G.729ab, G.726, T.38
- IP Telephony Features
- Echo cancellation, comfort noise generation (CNG), voice activity detection (VAD), call forwarding, Caller ID, call waiting, call hold, call transfer, silence suppression, DTMF generation/detection
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , Phone line: 1 x FXO - RJ-11 , Phone line: 4 x FXS - RJ-11 , USB 2.0: 2 x 4 pin USB Type A , WAN: 2 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- External detachable
- Antenna Qty
- 2
- Gain Level
- 2.2 dBi
- Power Device
- External power adapter
- Voltage Required
- AC 120/230 V
- Cables Included
- 1 x network cable , 1 x phone cable
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
