The industry-standard Cisco Small Form-Factor Pluggable (SFP) Gigabit Interface Converter links your switches and routers to the network. The hot-swappable input/output device plugs into a Gigabit Ethernet port or slot.
- Cisco - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - LC/PC multi-mode
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-SX
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 1 km
- 1.3 cm x 5.7 cm x 0.9 cm
- 75 g
- 90 days warranty
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-SX
- 1GbE
- 1 Gbps
- 850 nm
- 1 km
- Hot swap module replacement, Digital Optical Monitoring (DOM) support
- IEEE 802.3z, IEEE 802.3ah
- 1 x Ethernet 1000Base-SX - LC/PC multi-mode x 2
- Laser Class 1, IEC 60825-1
- 1.3 cm
- 5.7 cm
- 0.9 cm
- 75 g
- Limited warranty - 90 days
- -5 °C
- 85 °C
