Cisco Power Adapter AC 100/240 V For Aironet 702i Controller Based
Quicklinx: CG86WS00 Mfr#: AIR-PWR-C=
Cisco - Power adapter - AC 100/240 V - for Aironet 702i Controller-based, 702i Standalone, 702W
  • Efficient compatibility
    Designed specifically for PC use, this power adapter ensures seamless compatibility and efficient power delivery to your devices.
  • Optimal power management
    With a voltage provision of 48 V and the ability to operate on a wide range of input voltages (AC 100 / 240 V), this adapter is engineered for optimal power management and efficiency.
  • Versatile design
    The external form factor of the power adapter makes it a versatile addition to your tech toolkit, allowing for easy Plug-and-Play functionality across various setups.
Cisco - power adapter
Power adapter - external
Input Voltage
AC 100/240 V
Output Voltage
48 V
Input Voltage
AC 100/240 V
Frequency Required
50/60 Hz
Output Voltage
48 V
Cisco Aironet 702i Controller-based, 702i Standalone, 702W
