The Cisco Nexus 3524 switches are compact one-rack-unit (1RU) form-factor 10 Gigabit Ethernet switches that provide line-rate Layer 2 and 3 switching with ultra-low latency. The Cisco Nexus 3524 switches contain no physical layer (PHY) chips, allowing low latency and low power consumption. These switches support both forward and reversed airflow schemes and both AC and DC power inputs.
Robust security
With advanced encryption algorithms including AES and MD5, alongside authentication methods such as RADIUS, TACACS+, and Secure Shell v.2 (SSH2), this switch ensures secure network access and data integrity. -
High performance
Boasting a switching capacity of 960 Gbps and a forwarding performance of 720 Mpps, the Cisco Nexus 3524x efficiently manages data traffic, ensuring high-speed connectivity and reliable performance for demanding enterprise environments. -
Extensive connectivity
Equipped with 24 SFP+ Ports on Demand, the switch offers flexible and scalable network connection options, supporting a wide range of bandwidth-intensive applications and services. -
Enhanced manageability
Featuring comprehensive remote management protocols including SNMP, RMON, CLI, and SSH-2, this switch simplifies network management, allowing for efficient monitoring and configuration. -
Durable design
With a mean time between failures (MTBF) of 317,030 hours and compliance with multiple safety and environmental standards, the Cisco Nexus 3524x is built for long-term reliability and sustainability in various operational conditions.
- Cisco Nexus 3524x - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - L3 - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 24 x SFP+ Ports on Demand + 24 x SFP+
- Performance
- Switching capacity: 960 Gbps , Forwarding performance: 720 Mpps
- Capacity
- Virtual interfaces (VLANs): 4096 , Multiple Spanning Tree Protocol instances: 64 , Rapid Spanning Tree Protocol instances: 512 , ACL entries: 4096 , IPv4 routes (Unicast): 24000 , IPv4 hosts: 64000 , IPv4 routes (Multicast): 8000 , OSPF routes: 256
- MAC Address Table Size
- 64K entries
- Jumbo Frame Support
- 9216 bytes
- Routing Protocol
- OSPF, RIP-2, HSRP, VRRP, OSPFv2, static IP routing, ECMP, CIDR
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON, Telnet, SNMP 3, SSH-2, CLI
- Flow control, NAT support, BOOTP support, ARP support, trunking, VLAN support, Syslog support, Broadcast Storm Control, Multicast Storm Control, RSTP support, MSTP support, TFTP support, ACL support, EIGRP Stub Routing, STP Root Guard, UDLD, Rapid PVST+, DHCP relay, NTP time synchronisation, STP PortFast, CoS, PTP, 18MB packet buffer
- IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3ba, IEEE 802.1AX, IEEE 1588-2008
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- 43.9 cm x 46.7 cm x 4.36 cm
- 7.9 kg
- 1-year warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 64K entries
- 9216 bytes
- Routing Protocol
- Encryption Algorithm
- MD5, AES
- Authentication Method
- RADIUS, TACACS+, MS-CHAP, Secure Shell v.2 (SSH2)
- Flash Memory
- 2 GB
- 1 x serial (console) RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 24 x SFP+ , 2 x USB Type A , 24 x SFP+ Ports on Demand
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Power Provided
- 400 Watt
- Voltage Required
- MTBF
- 317,030 hours
- CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, GB 4943, Directive 2004/108/EC, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2006/95/EC, VCCI Class A, KN24, KN22 Class A, EN 55022 Class A, EN 300 386
- Software Included
- Cisco NX-OS
- 43.9 cm
- 46.7 cm
- 4.36 cm
- 7.9 kg
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 85% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95% (non-condensing)
Cisco 10GBASE-SR SFP Module | In Stock | £358.13 |
Cisco 10GBASE-CU SFP+ CABLE 5 METER | In Stock | £112.87 |
Cisco 10GBASE-CU SFP+ Cable 1 Meter | In Stock | £75.29 |
Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m | In Stock | £61.56 |
Cisco SFP+ Copper Twinax Cable 2m - Brown | In Stock | £99.62 |
Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC | In Stock | £1,478.92 |
Cisco 1000BASE-T SFP Transceiver | In Stock | £175.27 |
