Cisco SFP (mini-GBIC) transceiver module with Gigabit Ethernet for Cisco 20-port 1-Gigabit; Nexus 7700 F3-Series, 9372PX, 9396PX
Efficient connectivity
The Cisco SFP (mini-GBIC) transceiver module offers wired connectivity technology, ensuring a stable and efficient link for network communications. Its Gigabit Ethernet data link protocol supports a data transfer rate of 1 Gbps, making it ideal for high-speed data transmission needs. -
Versatile temperature range
Designed to operate in a wide range of temperatures, this module can function optimally in environments as cold as -5°C and as hot as 85°C. This feature ensures reliable performance in various operating conditions. -
Easy integration
With its plug-in module form factor and hot swap module replacement feature, this transceiver module can be easily integrated into existing network setups without significant downtime, facilitating seamless upgrades and maintenance.
- Cisco - SFP (mini-GBIC) transceiver module - 1GbE
- SFP (mini-GBIC) transceiver module - RJ-45
- Form Factor
- Plug-in module
- Cabling Type
- 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Data Link Protocol
- 1GbE
- Designed For
- Cisco 20-port 1-Gigabit Ethernet Modular Port Adapter; Catalyst ESS9300 Embedded Series; Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118; Nexus 7700 F3-Series 48-Port Fiber 1 and 10G Ethernet Module, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX, 9372PX-E, 9396PX, 9396PX Hot Air Exhaust
- Form Factor
- Plug-in module
- Connectivity Technology
- Wired
- Cabling Type
- 1000Base-T
- 1GbE
- 1 Gbps
- Full duplex capability, hot swap module replacement
- IEEE 802.3
- 1 x Ethernet 1000Base-T - RJ-45
- -5 °C
- 85 °C
- Designed For
- Cisco 20-port 1-Gigabit Ethernet Modular Port Adapter , Cisco Catalyst ESS9300 Embedded Series , Cisco Integrated Services Router 1111, 1112, 1113, 1116, 1117, 1118 , Cisco Nexus 7700 F3-Series 48-Port Fiber 1 and 10G Ethernet Module, 93108TC-EX, 93180YC-FX, 9336C-FX2, 9372PX, 9372PX-E, 9396PX, 9396PX Hot Air Exhaust
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
CZV1 050451 Condition: item has been used and came back with no packaging |
£57.32 |
Legend
This part of the stock item is present and in good condition
This part of the stock item is not present or functional
This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
This part of the stock item is not applicable e.g. it might not include accessories or software as standard
This item has not been tested.
