Cisco Nexus 3524x Switch L3 Managed  24 x SFP 10G Ports
Quicklinx: D6V4WS00 Mfr#: N3K-C3524P-10GX
Type: 10 Gigabit Ethernet
Ports: 24
Managed: Yes
£8,981.80 ex VAT
£10,778.16 inc VAT
The Cisco Nexus 3524 switches are compact one-rack-unit (1RU) form-factor 10 Gigabit Ethernet switches that provide line-rate Layer 2 and 3 switching with ultra-low latency. The Cisco Nexus 3524 switches contain no physical layer (PHY) chips, allowing low latency and low power consumption. These switches support both forward and reversed airflow schemes and both AC and DC power inputs.
  • Robust security
    With advanced encryption algorithms including AES and MD5, alongside authentication methods such as RADIUS, TACACS+, and Secure Shell v.2 (SSH2), this switch ensures secure network access and data integrity.
  • High performance
    Boasting a switching capacity of 960 Gbps and a forwarding performance of 720 Mpps, the Cisco Nexus 3524x efficiently manages data traffic, ensuring high-speed connectivity and reliable performance for demanding enterprise environments.
  • Extensive connectivity
    Equipped with 24 SFP+ Ports on Demand, the switch offers flexible and scalable network connection options, supporting a wide range of bandwidth-intensive applications and services.
  • Enhanced manageability
    Featuring comprehensive remote management protocols including SNMP, RMON, CLI, and SSH-2, this switch simplifies network management, allowing for efficient monitoring and configuration.
  • Durable design
    With a mean time between failures (MTBF) of 317,030 hours and compliance with multiple safety and environmental standards, the Cisco Nexus 3524x is built for long-term reliability and sustainability in various operational conditions.
Cisco Nexus 3524x - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - L3 - Managed
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
24 x SFP+ Ports on Demand + 24 x SFP+
Performance
Switching capacity: 960 Gbps , Forwarding performance: 720 Mpps
Virtual interfaces (VLANs): 4096 , Multiple Spanning Tree Protocol instances: 64 , Rapid Spanning Tree Protocol instances: 512 , ACL entries: 4096 , IPv4 routes (Unicast): 24000 , IPv4 hosts: 64000 , IPv4 routes (Multicast): 8000 , OSPF routes: 256
MAC Address Table Size
64K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
OSPF, RIP-2, HSRP, VRRP, OSPFv2, static IP routing, ECMP, CIDR
Remote Management Protocol
SNMP 1, SNMP 2, RMON, Telnet, SNMP 3, SSH-2, CLI
Flow control, NAT support, BOOTP support, ARP support, trunking, VLAN support, Syslog support, Broadcast Storm Control, Multicast Storm Control, RSTP support, MSTP support, TFTP support, ACL support, EIGRP Stub Routing, STP Root Guard, UDLD, Rapid PVST+, DHCP relay, NTP time synchronisation, STP PortFast, CoS, PTP, 18MB packet buffer
IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3ba, IEEE 802.1AX, IEEE 1588-2008
Power Redundancy
43.9 cm x 46.7 cm x 4.36 cm
7.9 kg
1-year warranty
Enclosure Type
Rack-mountable 1U
Subtype
10 Gigabit Ethernet
Ports
Performance
64K entries
Jumbo Frame Support
9216 bytes
Routing Protocol
Encryption Algorithm
MD5, AES
Authentication Method
RADIUS, TACACS+, MS-CHAP, Secure Shell v.2 (SSH2)
Flash Memory
2 GB
1 x serial (console) RJ-45 , 1 x management (Gigabit LAN) RJ-45 , 24 x SFP+ , 2 x USB Type A , 24 x SFP+ Ports on Demand
Installed Qty
2
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
Power Provided
400 Watt
MTBF
317,030 hours
CISPR 22 Class A, BSMI CNS 13438 Class A, CISPR 24, EN 61000-3-2, EN 61000-3-3, EN55024, AS/NZS 60950-1, ICES-003 Class A, RoHS, UL 60950-1 Second Edition, GB 4943, Directive 2004/108/EC, CSA C22.2 No. 60950-1 Second Edition, EN 60950-1 Second Edition, IEC 60950-1 Second Edition, Directive 2006/95/EC, VCCI Class A, KN24, KN22 Class A, EN 55022 Class A, EN 300 386
Software Included
Cisco NX-OS
43.9 cm
46.7 cm
4.36 cm
7.9 kg
Limited warranty - 1 year
10 - 85% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95% (non-condensing)
D6V4 Cisco 10GBASE-SR SFP Module In Stock £380.73
D6V4 Cisco 10GBASE-CU SFP+ CABLE 5 METER In Stock £113.51
D6V4 Cisco 10GBASE-CU SFP+ Cable 1 Meter In Stock £75.67
D6V4 Cisco SFP+ Copper Twinax Cable - SFP+ - SFP+ - 3m In Stock £61.91
D6V4 Cisco SFP+ Transceiver Module 10 Gigabit Ethernet 10GBase-LR LC/PC In Stock £1,507.03
D6V4 Cisco 1000BASE-T SFP Transceiver In Stock £185.12
Ports: 24
Managed: Yes
Brand: Cisco
Price Range Ex VAT: £1500+
