Cisco EHWIC-4ESG-P= Four port 10/100/1000 Ethernet
Quicklinx: 7L4LWS00 Mfr#: EHWIC-4ESG-P=
The Cisco Gigabit Ethernet Enhanced High-Speed WAN interface cards (EHWICs) can reduce your company's total cost of ownership (TCO) by integrating Gigabit Ethernet (GE) switch ports. These low-density Gigabit Ethernet switches offer small to medium-sized business (SMB) and enterprise branch-office customers a combination of switching and routing integrated into a single device. The Gigabit Ethernet EHWICs provide line-rate Layer 2 switching across onboard Gigabit Ethernet ports.
Cisco Gigabit EtherSwitch EHWIC - switch - 4 ports - Managed - plug-in module
Switch - 4 ports - Managed
Enclosure Type
Plug-in module (EHWIC)
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE)
Power Over Ethernet (PoE)
PoE
Routing Protocol
OSPF, HSRP, VRRP
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, HTTP, TFTP, CLI
Auto-sensing per device, power over Ethernet (PoE), VPN support, auto-negotiation, trunking, VLAN support, auto-uplink (auto MDI/MDI-X), IGMP snooping, Weighted Round Robin (WRR) queuing, Spanning Tree Protocol (STP) support, Per-VLAN Spanning Tree (PVST), Quality of Service (QoS), Jumbo Frames support
IEEE 802.3, IEEE 802.3u, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.1x
7.9 cm x 12.2 cm x 2.1 cm
108 g
Enclosure Type
Subtype
Gigabit Ethernet
Ports
PoE
Routing Protocol
OSPF, HSRP, VRRP
Encryption Algorithm
SSL
Authentication Method
Extensible Authentication Protocol (EAP)
Status Indicators
Port status
4 x 1000Base-T RJ-45 PoE
7.9 cm
12.2 cm
2.1 cm
108 g
10 - 90% (non-condensing)
7L4L C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
