Cisco Connectors/Cabinet Power Cord 250 VAC
Quicklinx: 9R62WS00 Mfr#: CAB-C15-CBN=
Length: 69cm
Hurry, only 2 left in stock!
£22.23 ex VAT
£26.67 inc VAT
Cisco is the worldwide leader in networking for the Internet. Cisco provides the broadest line of solutions for transporting data, voice and video within buildings, across campuses, or around the world. Cisco solutions ensure that networks both public and private operate with maximum performance, security, and flexibility.
  • Versatile compatibility
    Designed to seamlessly integrate with PCs, the Cisco Jumper power cable ensures a reliable connection between your computer and its peripherals. Its compatibility with a wide range of devices makes it an essential accessory for any PC setup.
  • Durable connectors
    Featuring a power IEC 60320 C15 left connector and a power IEC 60320 C14 right connector, each with a quantity of 1, this cable is built for longevity. The robust design ensures a secure and stable connection, minimizing the risk of disconnection or power interruption.
Cisco Jumper - power cable - IEC 60320 C15 to IEC 60320 C14 - 69 cm
Power cable
Length
69 cm
Connector
Power IEC 60320 C15
Connector (Second End)
Power IEC 60320 C14
Catalyst 9200L, 9300L; MDS 9020 Fabric Switch, 9120 Multilayer Fabric Switch, 9140 Multilayer Fabric Switch, 9216 Multilayer Fabric Switch, 9216A Multilayer Fabric Switch, 9216i Multilayer Fabric Switch
Power cable
Length
69 cm
Connector
Power IEC 60320 C15
Power IEC 60320 C14
Cisco Catalyst 9200L, 9300L , Cisco MDS 9020 Fabric Switch, 9120 Multilayer Fabric Switch, 9140 Multilayer Fabric Switch, 9216 Multilayer Fabric Switch, 9216A Multilayer Fabric Switch, 9216i Multilayer Fabric Switch
Length: 69cm
Brand: Cisco
